Finally got around to building up my DJ-105 - it's just PLA at the moment, but will be printing it out with Taulman 910 once I finish my Anet A6 enclosure...
Easy build compared to a RS90 and using the below components - just waiting on the FPV Tx to turn up:
1 x Mini ACRO F4 Betaflight Flight Controller Buil-in PDB 5V/1A BEC with Micro Buzzer
1x FrSky XSR (de-pinned)
4x RCX H1304 4000KV Multirotor Brushless Motors
4x Racerstar RS20A V2 20A Blheli_S OPTO 2-4S ESC
4x Racerstar 2530 R-DD65X3 65mm 3 Blade Propeller 1.5mm Mounting Hole
1x 700TVL 1/4 Cmos 1.8mm 170 Degree FPV Camera NTSC/PAL 3.7-5V
1x Eachine VTX01 Super Mini 5.8G 40CH 25mW FPV Transmitter
Will be running 2S and 3S NanoTech 450mAh batteries
Having a slight issue in that the quad flips as soon as power is applied - I've treble checked the motor wire numbering, motor and prop direction as well as the inversion of the FC in BetaFlight 3.1 (making sure to re-run the calibration).
Anything else that I haven't checked/thought of please?
