If you enjoy our forum, why not join us? :) Click here to register in a few simple steps
  • 1 Vote(s) - 4 Average
DIY 2S 3000mah Li-Ion battery upgrade for Fat Shark goggles
(10-27-2016, 05:05 PM)Simon Wrote: So if I use a 18650 series battery sled, so I can charge the battery independently on an18650 charger..... I'll only need to connect the pos and neg from the balance plug to power the fan?
Yes, you only need the positive and negative wire on the balance plug for the fan to work
  • Simon
(09-12-2016, 06:21 PM)Xtopher98 Wrote: Is it dangerous to solder directly onto a battery? That seems unsafe.
It can be if you apply too much heat to the battery. Be careful.
If it isn't broke, fix it anyways!
And don't make a short circuit with your solder iron.
#19
(10-28-2016, 02:21 PM)Ikkuh Wrote: And don't make a short circuit with your solder iron.
Ah, yes....voice of experience?  (I did that once - scared the crap out of me!) Big Grin
#20
No lucky not, but I was still a bit nervous when I have to solder 3 pieces of 3S 5000 mAh batteries. I saw the movies what could happend so extra careful.
[-] The following 1 user Likes Ikkuh's post:
  • sloscotty
#21
@christopher, heating up any battery is not smart, putting soldering iron there not safe, yet if you apply flux and do the soldering quickly you are good to go, i've salvaged few cells from dead batteries( good practice) and turned dead 4s to 3s and dead 3s to 2s only watchout for shorts "bzzzzzzz"
All the best
Grzesiek (Grisha/ Greg)
Curently flyable: Nox 5, Nox 3, Minimalist 112, Scrap
Bench / in progres: fixing
thinking about building: 450
#22
Don't buy the batteries in the video. They are cheap Chinese JUNK! Buy either Samsung 25r, LG he4/he2 or Sony VTC4/VTC5. I am using the LG HE4 with my base station and they will run for over a hour of run time.
  Battery Phantom 3 battery inside Verid 0 60 03-20-2017, 01:36 PM
Last Post: Verid
  Tutorial Phantom 2 battery hack Verid 1 223 02-08-2017, 08:48 PM
Last Post: Justynkace
  Goggles Clean DVR install on Quanum Goggles KonradS 25 2,106 01-21-2017, 12:43 AM
Last Post: Drone0fPrey
  Tutorial Antena upgrade to dipole (out of salvaged parts) Grisha0 0 229 12-07-2016, 08:30 PM
Last Post: Grisha0
  Accessory Add a DVR to your FPV Goggles for only 25 USD! Michael Grabner 2 1,000 05-17-2016, 08:53 AM
Last Post: Michael Grabner
