  • 1 Vote(s) - 4 Average
DIY 2S 3000mah Li-Ion battery upgrade for Fat Shark goggles
(27-Oct-2016, 05:05 PM)Simon Wrote: So if I use a 18650 series battery sled, so I can charge the battery independently on an18650 charger..... I'll only need to connect the pos and neg from the balance plug to power the fan?
Yes, you only need the positive and negative wire on the balance plug for the fan to work
  • Simon
(12-Sep-2016, 06:21 PM)Xtopher98 Wrote: Is it dangerous to solder directly onto a battery? That seems unsafe.
It can be if you apply too much heat to the battery. Be careful.
If it isn't broke, fix it anyways!
And don't make a short circuit with your solder iron.
#19
(28-Oct-2016, 02:21 PM)Ikkuh Wrote: And don't make a short circuit with your solder iron.
Ah, yes....voice of experience?  (I did that once - scared the crap out of me!) Big Grin
#20
No lucky not, but I was still a bit nervous when I have to solder 3 pieces of 3S 5000 mAh batteries. I saw the movies what could happend so extra careful.
[-] The following 1 user Likes Dutch Drone Builder's post:
  • sloscotty
#21
@christopher, heating up any battery is not smart, putting soldering iron there not safe, yet if you apply flux and do the soldering quickly you are good to go, i've salvaged few cells from dead batteries( good practice) and turned dead 4s to 3s and dead 3s to 2s only watchout for shorts "bzzzzzzz"
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
#22
Don't buy the batteries in the video. They are cheap Chinese JUNK! Buy either Samsung 25r, LG he4/he2 or Sony VTC4/VTC5. I am using the LG HE4 with my base station and they will run for over a hour of run time.
#23
(24-Mar-2016, 09:23 PM)T-Bone FPV Wrote: On my charger there is a li-ion setting.  I just use the fatshark charge lead and balance charge them at 3amps.    But I really don't see why lipo setting wouldnt work.  They still charge to 4.2v/cell.
Yeah 18650s and I just bought the highest reviewed ones I could for the lowest price on Amazon and they worked just fine Smile
For 18650 manufacturer recommend charging at only 0.5C. You can use the Lipo setting without problem.
#24
(28-Oct-2016, 02:26 PM)sloscotty Wrote: Ah, yes....voice of experience?  (I did that once - scared the crap out of me!) Big Grin
That is why I made a MOT spot welder with an Arduino for timer control. Much safer. One of these days when I have time, I will write a tutorial.
  Tutorial DIY Frames - Handy Man Specials iFly4rotors 7 1,502 23-Dec-2023, 09:59 PM
  Tutorial 6S1P Li-ion 3500mAh Long Range Pack FlyerFpv 20 7,292 17-Nov-2022, 07:02 PM
  Tutorial Soldering peripheral leads to battery connections roger74 1 502 08-Oct-2022, 07:35 AM
  Tutorial DIY Mini Rotary Tool - Drill || Grinder || Cutter || Polisher || - A2212 1000KV Brush sim_tcr 1 807 24-Dec-2021, 03:51 PM
  wiring to upgrade camera fasinfrank 2 440 27-Oct-2021, 10:18 PM
Last Post: kafie1980
