21-Jul-2016, 10:33 PM
Dudes, can anyone tell me what the difference between uart and spi is? I've read all of them internets and I'm still confused
Difference between UART and SPI? |
21-Jul-2016, 10:33 PM Dudes, can anyone tell me what the difference between uart and spi is? I've read all of them internets and I'm still confused 21-Jul-2016, 10:34 PM To be simple: uart is a serial port on your flight controller usually it has 2 or 3 uarts to connect external devices like serial capable Rx, osd, gps or others. SPI is a communication protocol between the FCs main chip and it's other components mainly the gyro, or if it has, the on-board flash chip. 21-Jul-2016, 10:48 PM In a nutshell, both are serial communication protocols, UART is from one device to another, and cannot have more than one device connected to it at a time. TX and RX on each side and TX of one connects to RX of the other and vice versa. SPI is serial peripheral interface, it's used to connect several peripherals to one "master" usually a micro controller in this case your flight controller. There are 4 wires, clock, MOSI, MISO and /CS. MOSI is master output slave input, so from the master to the slave, and MISO is from the slave to the master. /CS is chip select, when this signal is low (0V) then that specific peripheral has control over the bus and any data on the bus is for it and the master alone, it basically tells the other chips to not listen. Clock is used to synchronize the master and slaves. In UART there is no clock wire, so the baud rate (basically correlated to the time between each bit) is predetermined so both sides can decode the serial. |
Question: PID in quad, error is difference between what? | E.L.K. | 5 | 1,042 | 11-Sep-2017, 08:02 AM Last Post: E.L.K. | |
Does Betaflight OSD use UART? | Charpu5 | 1 | 1,626 | 22-Aug-2017, 10:56 PM Last Post: Oscar |
