Threads: 75
Likes Given: 3,949
121 I’m all for servo’s recycling suggestion.
Those thin semi rigid plastic shelf liners would probably work as well.
When the pandemic first started I was using clear plastic sheets to make face shields- those would probably be perfect. I’ll hafta see if I have any left or if I can figure what they were.
Dangerous operations.
Threads: 392
Likes Received: 3,231 in 1,827 posts
Likes Given: 3,214
101 The only thing I'm worried about is if the motors start burning up and melt the plastic. I'm thinking maybe a thin silicone sheet cut to small circles.
Threads: 75
Likes Given: 3,949
121 My only concern with silicone sheets is that it would be a little floppy. I’m guessing you’re thinking of cutting circles, hole punch in the middle, with a slit to get it around the post? If it flopped around in flight and managed to get caught up in the bell it could go horribly wrong.
Threads: 392
Likes Given: 3,214
101 Good call. Got another brain fart - kapton tape. Two layers stuck to each other, cut out circle, punch hole in middle, cut line to that hole. Might be simple enough to actually work lol.
Threads: 75
Likes Given: 3,949
121 …that actually might be perfect.
Threads: 392
Likes Given: 3,214
101 I'm gonna start doing this. I can't tell you how much $$$ I have literally burned from screws shorting motors. I use TPU motor pads as well as landing skids so it makes things a little more tricky as that screw keeps getting deeper as it settles.
Threads: 75
Likes Given: 3,949
121 Let me know how the kapton tape works, I’d like to do it for mine as well.
