Diatone SP3 Cable set
Where can I purchase the cable set for OSD on the VTX to UART on the FC and the other wire set from the VTX to + and – on the FC and to the camera. Basically the the wires in the second pic in the “Wiring (In My Quad) section” on your Oscarliang.com page.  Thanks!
Hi, those cables are in set with SP3 - in the package (actually 2 sets if you will break one), so it is already there.
cable for connection
from SP3 to FC - 2 pieces
from SP3 to camera / power - 2 pieces
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
(07-Dec-2016, 08:58 PM)Grisha0 Wrote: Hi, those cables are in set with SP3 - in the package (actually 2 sets if you will break one), so it is already there.
Actually what I'm looking for are the pre-spliced cable.  I had the wires you mentioned in my sp3 but I still had to splice those wire together.
hmmm in my case i've soldered the cables to FC and the plug went into the SP3, if you have plugs on each end then either solder the 2 cables together or connect it otherwise...
fyi im not a fan of connectors on FC
All the best
  SkyZone SKY04X: Value of a Secondhand Goggle, Fixing Scratches, Cable Break runfpv 8 584 18-Jun-2023, 06:14 PM
Last Post: runfpv
  Help Caddx Turtle v2 coax cable replacement cst3x6 9 736 08-Mar-2023, 10:36 PM
Last Post: cst3x6
  Solved Iflight mini vtx not retaining set up information Cdog 9 863 24-Mar-2022, 01:34 AM
Last Post: Cdog
  Old Fat shark Cable Help Eddie-Furniss 4 518 22-Aug-2021, 01:29 PM
Last Post: Eddie-Furniss
  HDO2 ribbon cable torn... JinxFPV 3 622 08-Jun-2021, 09:00 PM
Last Post: JinxFPV
