Threads: 1
Likes Received: 0 in 0 posts
0 Where can I purchase the cable set for OSD on the VTX to UART on the FC and the other wire set from the VTX to + and – on the FC and to the camera. Basically the the wires in the second pic in the “Wiring (In My Quad) section” on your Oscarliang.com page. Thanks!
Threads: 56
Likes Received: 335 in 196 posts
Likes Given: 183
15 07-Dec-2016, 08:58 PM (This post was last modified: 07-Dec-2016, 08:59 PM by Grisha0.) Hi, those cables are in set with SP3 - in the package (actually 2 sets if you will break one), so it is already there.
cable for connection
from SP3 to FC - 2 pieces
from SP3 to camera / power - 2 pieces
All the best
Grzesiek (Grisha/ Greg)
Curently flyable: Nox 5, Minimalist 112
Bench / in progres: fixing Nox 3, Scrap
thinking about building: 450
Threads: 56
Likes Given: 183
15 hmmm in my case i've soldered the cables to FC and the plug went into the SP3, if you have plugs on each end then either solder the 2 cables together or connect it otherwise...
fyi im not a fan of connectors on FC
All the best
