Diatone Mamba F722 35A Mk1 CLI Dump
Good morning everyone. Can anyone help share the CLI Dump file for the Diatone Mamba F722 35A MK1 please. I did a reset on betaflight and am unable to locate the backup file in my computer. Please help me. Thank you.
Dr. Saravanan
If this is just a plain flight controller that isn't installed in a BNF quad then all you need to do is to run the "defaults" command in the CLI and it will set the configuration back to the default values for the installed Betaflight target.
If you have flashed the wrong target to the FC by mistake then you just need to flash the MAMBAF722 target to it, then connect Betaflight Configurator to the FC and click on the "Apply Custom Defaults" button when prompted.
  • Doc
Hi SnowLeopardFPV. It is a BNF with the following build:
DIATONE Roma L5 Freestyle Multirotor (6S) PNP
Camera: RUNCAMPHOENIX 2
Antenna: MAMBA UltraRHCP
VTX: MAMBA Ultra Tiny 400mW
FC:MAMBA F722 AIO MK1
ESC:MAMBA 35A 8BIT
Motor: MAMBA2004 1700KV
GPS :M8PLUS
Is there another work around for me? Can i reconfigure from scratch? Please advise. Thanks
Hi, i found this off the net.
https://drive.google.com/file/d/1kT04KVc...sp=sharing
Can i use this? Thanks
[-] The following 1 user Likes Doc's post:
  • Pesdegato
(15-Jun-2021, 09:41 AM)Doc Wrote: Hi, i found this off the net.
hi, ive made the same mistake, LOOK IVE JUST FOUND THIS  ( https://www.rcgroups.com/forums/showthre...nalogue%29 ) we are save!!!
  Need dump file for iFlight Nazgul Evoque F5D iShi 1 220 03-May-2024, 01:11 PM
  Where can I find the Mamba F722_2022A controller factory presets? phelipems 2 176 10-Apr-2024, 03:55 PM
Last Post: phelipems
  CLI commenting #$ zomer 7 499 27-Aug-2023, 11:05 PM
Last Post: zomer
  Modes tab CLI zomer 2 387 20-Aug-2023, 02:45 PM
Last Post: BadRaven
  How to execute this config.h in BT CLI zomer 6 458 15-Aug-2023, 03:33 PM
Last Post: zomer
