Diatone ET200
Exclamation
Diatone ET200 frame from Diatone Innovations
This little frame is very nice designed and quick to setup thanks to the integrated PDB.
I would say it's a good FPV cruiser.
After the first build I have decided to re-design the quad since I notice some weak points mainly in the arms which are supported by only two standoffs and screws .
So I added some customized 3D printed parts which make this quad tougher at the weak points and prettier, well that is my opinion anyway  Tongue
My setup
Frame: Diatone ET200 frame
Motors: Powered by DYS BE1806 2300Kv - Black edition
Esc's: ZTW Spider opto 12A with oneshot
FC: EMAX mini Skyline32 Naze32
Vtx: Dal RC DIY 5.8Ghz 600mw Vtx + Cooling sink
FPV antennas: FPV 5.8G Gain Petals Clover Mushrooms Antenna TX/RX Set
FPV cam: 600TVL 1/4 1.8mm CMOS FPV 170 Degree Wide Angle Lens
OSD: Micro minimosd
Rx: X8R
Props: Gemfan 5045 ABS CW/CCW Propeller For Mini Quadcopter 250
Batts: Nano tech 3s 1300Mah or can run with 4s setup as well
Customized 3d printed parts: contact me
AUW: 420g
  Diatone c25 mk2 3d print Wolfplay 0 190 16-Aug-2023, 08:08 PM
Last Post: Wolfplay
  Build Hybrid Diatone Roma 5" relentlesstech 7 458 29-Jun-2022, 11:27 PM
Last Post: relentlesstech
  Review Diatone Roma F5 review (6S analog version) L0stB1t 87 24,866 16-Feb-2022, 12:30 AM
Last Post: robegian
  Tutorial Diatone Mamba F722 mini FC - Part 1 ciscoarizona 11 1,434 02-Jun-2021, 10:02 PM
Last Post: rolo95
  Tutorial Diatone Mamba F722 - Part 2 PID Tuning ciscoarizona 1 832 25-May-2021, 02:21 AM
Last Post: the.ronin
