16-Mar-2022, 07:03 AM (This post was last modified: 16-Mar-2022, 08:10 AM by joewickert. Edit Reason: Added Blacbox log as textfile, hadn't correctly attached before )
OK, I think I need some help on this one.
I've been building little quads to stay under weight limits and made all the usual mistakes but starting to get OK at the basics.
But I thought I should really get a 5inch build going, it's a bit of a mashup of old parts, cheap bits and cable ties.
It takes off nice but as soon as I try any flips or rolls it death spins out of the air and hits the ground hard.
Here's a video of the latest crash:
Setup is:
CLRACING F7 V2.1 MPU6000 30X30 FLIGHT CONTROLLER
FLYCOLOR RAPTOR BLS 30A 4IN1 ESC (2-4S)
Racerstar SPROG X 2207 2400KV 3-5S
HSKRC Foss 210 4mm Arm 3K Carbon Fiber 5 Inch
Chinahobbyline CNHL G+PLUS 1300MAH 14.8V 4S 100C Lipo
8k looptime and RPM filtering as per Oscar's blog post setup. Air mode is on.
Arms (were) nice and stiff.
Here's a pic after that crash. Whoops, guess it'll need a new frame.
The Blackbox log is attached, I don't know how to read it properly but should motor 1 be jumping to 100% after the roll be a concern.
The flight controller is new as the old one ripped it's USB port off on the previous crash.
So I don't know, could it be:
- esc
- a motor
- a capacitor issue (wrong one, wires too long)
- or is the battery too big/loose? throwing things off balance?
Thanks in advance for any advice, it's appreciated.
Setup is:
- esc
- a motor
