18-Sep-2016, 02:24 PM
New alternative PPM RX for micro quads
This is even lighter than the SRP8 receiver we have seen previously.
SRP8 is 1.5g, the DasMikro PPM RX is only 0.4g!
http://www.banggood.com/DasMikro-FrSky-A...87850.html
Spec
Not only being lighter it's also smaller
Binding
1. Remove all power.
2. Turn your TX on in binding mode. (D8 mode on Taranis)
3. Connect the PPM to GND
4. Once bound you should get a steady slow blinking light
5. Remove all power
6. Make sure PPM and GND are no longer shorted(connected).
7. Reset TX or Turn off binding mode.
8. Turn on your TX and RX.
9. They should now be bound
Spec
- Size: 17mm*9mm*2mm
- intput voltage: 3.7-10.8V DC
- Tested and Supported TX: Frsky DJT module, Taranis
Binding
5. Remove all power
