Threads: 3
Likes Received: 0 in 0 posts
Likes Given: 3
0 Ok so I am trying to get this new fangled telemetry thingy going, and it kind of works.
Setup:
Naze32 rev5 with Betaflight 2.1.6
D4R-II
Taranis plus with openTX 2.0.19
I am getting signal from naze to radio. Was first running it off of the telemetry port, but then moved it over to pin 6 soft serial, same results on each setup.
Same results on openTX 2.0.19 and 2.1.7.
Here's the issue:
Battery calibration. I will put a fresh battery on and go fly. Life is good. Next battery, it seems as though the telemetry does not reset with battery change out and I have to re-calibrate for the fresh battery. Thoughts? Ideas? I'm a bit stumped.
Threads: 4
Likes Given: 3
0 Hi Scott,
Did you try holding the "Enter button, reset flight" on your Taranis?
Threads: 3
Likes Given: 3
0 Good to know of this feature, but did not work.
Threads: 672
Likes Given: 2,030
139 Hi, what isn't reset? Voltage level? You mean telemetry still stays at the voltage from last battery?
Very odd..
Have you try turning TX off and on?
Threads: 3
Likes Given: 3
0 Yeah the voltage is not resetting. Power cycling the tx doesn't seem to help. Works fine on sensor A1 for the internal rx voltage, but not A2. Watched the youtube videos and combed through the tutorials and set everything up as indicated. FC is reading voltage correctly in cleanflight and low voltage alarm on the quad works. Gonna try setting it up on a different model and see if I can get it to work with that one. Would an external voltage sensor help?
Threads: 3
Likes Given: 3
0 So it seems to be resetting after I refresh between batteries, however the voltage readout is all off. Looking at information online, it looks like I may have done the math wrong. What is the voltage divideo ratio on naze32?
Threads: 672
Likes Given: 2,030
139 Could be different on everyone's ... Adjust it by connecting to a Cleanflight GUI.. You should see flight data on home tab including voltage reading (when your lipo is connected too)
Adjust voltage scale in config tab, and check voltage... Repeat until you get it right?
Remember to remove props!
