Threads: 36
Likes Received: 83 in 46 posts
Likes Given: 124
4 I've noticed the more I fly that I will have great signal in an area then I can fly back to that area and starting getting interference. Is this just the nature of 5.8?
Quads: RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3
YouTube - Mr.E_fPv
Threads: 38
Likes Given: 1,881
72 Rain or fog will affect FPV signals, but I can't imagine you were flying in the rain. A storm front can also cause problems due to the large static charge.
If weather can be ruled out as a factor then maybe there are some microwave communications towers in the area? Depending on what they are, they may not be transmitting at all times.
Threads: 673
Likes Given: 2,031
139 how far out are you talking about? and what gear are you using (VTX/VRX/Antenna)?
Also note if you are flying close to buildings the chances are there could be interference from wifi
Threads: 36
Likes Given: 124
4 04-Jun-2017, 10:35 AM (This post was last modified: 04-Jun-2017, 10:35 AM by rryyyaann.) I'm guessing WIFI if it can do that. I'm using ReadyMadeRC cricket 200mw with eachine EV800. I was may 50 yards away in life of sight. I was flying down my street houses on both sides.
YouTube - Mr.E_fPv
Threads: 38
Likes Given: 1,881
72 There are some frequencies for WiFi that use the 5.8GHz band, but the highest frequency these channels use is 5.835GHz.
So, you might like to try using some of the FPV channels which are higher than that and see if it makes things better.
