Threads: 39
Likes Received: 5 in 4 posts
0 I recently finished a build using all KISS parts, and I'm really liking the current monitoring offered by this build.
I'd like to start using current monitoring on my other quads, but they are a variety of blheli/betaflight setups.
What current sensors are being used for mini quads with cleanflight/betaflight?
Threads: 24
Likes Received: 6 in 5 posts
Likes Given: 3
1 I use an RROSD, doesn't require any cleanflight/betaflight integration, e.g. it's totally standalone.
QuadRevo OSD Pro is another option, that gives you Timer, mah used, volts, and amps.
Threads: 15
Likes Received: 1 in 1 posts
5 The power modules that APM boards come shipped with send out current and voltage measurements to the fc.
They are quite small enough to solder onto a 250 pdb, maybe some clever placing could fit them on a 200 sized copter.
Might have one or two lying around. Maybe I'll see if I try one this weekend
