Threads: 1
Likes Received: 0 in 0 posts
0 Hi everyone!
I was looking into getting a Resin 3D printer.
Do many of you using them?
If so, what were the features that made you decide on the printer you have?
Also, what has been your experience with the resin printing process?
Thanks in advance!!
J
Threads: 1
0 This is awesome thanks!
What are you finding easy or hard about the resin print process?
How much space do you need for your setup?
Are you able to do your prints in the house or do you print in the garage?
Thanks again :-)
J
Threads: 125
Likes Given: 99
388 The hard part about resin printing is the cleaning. aside cleaning the model, as I already mentioned, a washing/curing unit is key. but the other cleaning is the print vat and the FEP cleaning. if you don't probably clean it well, you can't get the first layer to stick. When you get your printer, I can give you tips that will make your life that much easier.
The other difficult part is model orientation and support. My slicer has an optimal orientation and suggested supports for my printer. I haven't used any other slicer. But if you don't oriente properly, the first layer can peel away and ruin your print. I also more carefully check my model for proper support, more so than when I filament print.
The easy part is not having to finish you model. Most resin prints come out practically finished. The other nice thing, if your print messes up, the clean up is easy. Not like filament, which can be a big hairball and clot extruder.
Spacing isn't too much. But you do need space for the printer and washer. A little bit of room in front of the washer and printer to do some cleaning and set down stuff on the table.
I have a separate room in the house where I can open the windows. It depends on the resin you use. So have very strong smell and other do not.
Threads: 59
Likes Received: 592 in 395 posts
Likes Given: 210
42 I'm Clearly late to the party, and it looks like you already shared my reviews voodoo, thanks!
Resin printing is fun and different. Definitely recommend a wash and cure unit. Agree with most of what Voodoo has said.
