Threads: 67
Likes Received: 713 in 473 posts
Likes Given: 1,216
23 Anything is possible, but I would suspect some sort of physical damage....more then likely a bent prop? If it was bad enough could have a delaminated arm....but something is out of aligment or broken causing vibration which manifest itself as "jello" much of the time. Just my .02 cents worth.....
Threads: 83
Likes Received: 944 in 654 posts
Likes Given: 2,142
24 Bent motor shaft or loose motor or other screws. I agree with SirDude and would say that vibration is the most likely cause, does it sound different?
Threads: 12
Likes Received: 38 in 24 posts
Likes Given: 1
1 It can be a bent prop. When they bend, they get unbalanced. That might cause vibrations. I don't think the VTX got damaged, that should not cause jello.
