CPU Load 0%
Hello guys,
I have a question about my QX95 setup.
I have a cpu load of 0%, PID delta 990-1000, is this normal if it's on the bench?
Also i have 2 I2C errors.
If i move the quad the cpu load is still 0%
It's possible to fly the quad, it are just question out of curiosity
have you tried flashing the firmware again (make sure it's the correct firmware target)
try to turn off unused I2C devices see if it fixes it? such as Baro and Compass (mag).
I2C errors (afaik) happen during initialisation. As long as the number does not keep rising to infinity, you don't have to worry about that. At least that's what Boris said some time ago.
PS: You could check "status" or "tasks" in CLI. Another possible reason could be that it's running an older firmware which didn't support realtime CPU display back then?
I'm going to check your idea's i will report it back, and it's running now cleanflight 1.13 with the "problems"
Thank you for the idea's
  What happens when I load a Betaflight Preset Tune in my FC? husafreak 6 505 07-Nov-2023, 02:56 AM
Last Post: husafreak
  Discussion Flight Controller CPU Load Question OverDischarged 2 8,437 16-Nov-2016, 10:33 PM
Last Post: OverDischarged
Question SP Racing F3 - CPU Status %100 JimmyLe813 5 5,955 07-Aug-2016, 03:00 AM
Last Post: JimmyLe813
