continuous oscillation on motor signals
My quad (F450, about 1200g) flies quite good, but on each of the four motor signals, there is a continuous oscillation. How can I get rid of it?
[Image: ld5mDPrl.png]
Here my dump file:
Entering CLI Mode, type 'exit' to return, or 'help'
# dump
# INAV/SPRACINGF3 1.7.3 Sep  9 2017 / 10:20:09 (974440df)
# resources
# mixer
mixer QUADX
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mix
smix reset
feature -VBAT
feature -CURRENT_METER
feature -DASHBOARD
feature -BLACKBOX
feature -TRANSPONDER
feature -AIRMODE
feature -SUPEREXPO
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -PWM_SERVO_DRIVER
feature -PWM_OUTPUT_ENABLE
feature -OSD
feature VBAT
feature RX_SERIAL
feature GPS
feature BLACKBOX
feature PWM_OUTPUT_ENABLE
# beeper
beeper RUNTIME_CALIBRATION
beeper HW_FAILURE
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACTION_SUCCESS
beeper ACTION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper LAUNCH_MODE
# map
map AETR1234
# name
name -
serial 0 1 115200 38400 0 115200
serial 1 2 115200 115200 0 115200
serial 2 64 115200 38400 0 115200
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
aux 0 0 0 1500 2100
aux 1 1 0 1500 2100
aux 2 2 0 1500 2100
aux 3 3 5 1500 2100
aux 4 9 1 1300 1700
aux 5 8 1 900 1300
aux 6 17 4 1500 2100
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# master
set looptime = 2000
set gyro_sync = ON
set gyro_sync_denom = 2
set align_gyro = DEFAULT
set gyro_hardware_lpf = 42HZ
set gyro_lpf_hz = 42
set moron_threshold = 32
set gyro_notch1_hz = 170
set gyro_notch1_cutoff = 125
set gyro_notch2_hz = 85
set gyro_notch2_cutoff = 43
set vbat_adc_channel = 1
set rssi_adc_channel = 3
set current_adc_channel = 2
set airspeed_adc_channel = 0
set acc_notch_hz = 0
set acc_notch_cutoff = 1
set align_acc = DEFAULT
set acc_hardware = MPU6050
set acc_lpf_hz = 10
set acczero_x = 167
set acczero_y = 3
set acczero_z = -130
set accgain_x = 4062
set accgain_y = 4063
set accgain_z = 4025
set align_mag = DEFAULT
set mag_hardware = HMC5883
set mag_declination = 0
set magzero_x = -18
set magzero_y = -25
set magzero_z = -70
set mag_calibration_time = 30
set baro_hardware = MS5611
set baro_use_median_filter = ON
set pitot_hardware = NONE
set pitot_use_median_filter = ON
set pitot_noise_lpf =  0.600
set pitot_scale =  1.000
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_invert = OFF
set rc_smoothing = ON
set serialrx_provider = IBUS
set sbus_inversion = ON
set rx_spi_rf_channel_count = 0
set spektrum_sat_bind = 0
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set min_throttle = 1150
set max_throttle = 1850
set motor_pwm_rate = 400
set motor_pwm_protocol = STANDARD
set failsafe_delay = 5
set failsafe_recovery_delay = 5
set failsafe_off_delay = 200
set failsafe_throttle = 1000
set failsafe_procedure = RTH
set failsafe_stick_threshold = 50
set failsafe_fw_roll_angle = -200
set failsafe_fw_pitch_angle = 100
set failsafe_fw_yaw_rate = -45
set align_board_yaw = 0
set gimbal_mode = NORMAL
set battery_capacity = 0
set vbat_scale = 110
set current_meter_scale = 400
set current_meter_offset = 0
set current_meter_type = ADC
set yaw_motor_direction = 1
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lpf_hz = 20
set flaperon_throw_offset = 200
set tri_unarmed_servo = ON
set imu_dcm_ki = 50
set imu_dcm_kp_mag = 10000
set imu_dcm_ki_mag = 0
set small_angle = 25
set fixed_wing_auto_arm = OFF
set disarm_kill_switch = ON
set gps_provider = UBLOX
set gps_sbas_mode = AUTO
set gps_dyn_model = AIR_1G
set gps_auto_config = ON
set gps_auto_baud = ON
set gps_min_sats = 6
set deadband = 5
set yaw_deadband = 5
set pos_hold_deadband = 20
set alt_hold_deadband = 50
set fw_autotune_overshoot_time = 100
set fw_autotune_undershoot_time = 200
set fw_autotune_threshold = 50
set fw_autotune_ff_to_p_gain = 10
set fw_autotune_ff_to_i_tc = 600
set inav_auto_mag_decl = ON
set inav_gravity_cal_tolerance = 5
set inav_use_gps_velned = ON
set inav_gps_delay = 200
set inav_reset_altitude = FIRST_ARM
set inav_max_surface_altitude = 200
set inav_w_z_surface_p =  3.500
set inav_w_z_surface_v =  6.100
set inav_w_z_baro_p =  0.350
set inav_w_z_gps_p =  0.200
set inav_w_z_gps_v =  0.500
set inav_w_xy_gps_p =  1.000
set inav_w_xy_gps_v =  2.000
set inav_w_z_res_v =  0.500
set inav_w_xy_res_v =  0.500
set inav_w_acc_bias =  0.010
set inav_max_eph_epv =  1000.000
set inav_baro_epv =  100.000
set nav_disarm_on_landing = ON
set nav_use_midthr_for_althold = OFF
set nav_extra_arming_safety = ON
set nav_user_control_mode = ATTI
set nav_position_timeout = 5
set nav_wp_radius = 100
set nav_wp_safe_distance = 10000
set nav_auto_speed = 300
set nav_auto_climb_rate = 500
set nav_manual_speed = 500
set nav_manual_climb_rate = 200
set nav_landing_speed = 200
set nav_land_slowdown_minalt = 500
set nav_land_slowdown_maxalt = 2000
set nav_emerg_landing_speed = 500
set nav_min_rth_distance = 500
set nav_rth_climb_first = ON
set nav_rth_climb_ignore_emerg = OFF
set nav_rth_tail_first = OFF
set nav_rth_allow_landing = ON
set nav_rth_alt_mode = CURRENT
set nav_rth_abort_threshold = 50000
set nav_rth_altitude = 1000
set nav_mc_bank_angle = 20
set nav_mc_hover_thr = 1600
set nav_mc_auto_disarm_delay = 2000
set nav_fw_cruise_thr = 1400
set nav_fw_min_thr = 1200
set nav_fw_max_thr = 1700
set nav_fw_bank_angle = 20
set nav_fw_climb_angle = 20
set nav_fw_dive_angle = 15
set nav_fw_pitch2thr = 10
set nav_fw_loiter_radius = 5000
set nav_fw_land_dive_angle = 2
set nav_fw_launch_velocity = 300
set nav_fw_launch_accel = 1863
set nav_fw_launch_max_angle = 45
set nav_fw_launch_detect_time = 40
set nav_fw_launch_thr = 1700
set nav_fw_launch_idle_thr = 1000
set nav_fw_launch_motor_delay = 500
set nav_fw_launch_spinup_time = 100
set nav_fw_launch_timeout = 5000
set nav_fw_launch_climb_angle = 18
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_latitude =  0.000
set frsky_default_longitude =  0.000
set frsky_unit = METRIC
set frsky_vfas_precision = 0
set smartport_uart_unidir = OFF
set smartport_fuel_percent = OFF
set ibus_telemetry_type = 0
set ltm_update_rate = NORMAL
set i2c_speed = 400KHZ
set cpu_underclock = OFF
set debug_mode = GYRO
set acc_task_frequency = 500
set attitude_task_frequency = 250
set async_mode = GYRO
set throttle_tilt_comp_str = 0
set mode_range_logic_operator = OR
set stats = OFF
set stats_total_time = 0
set stats_total_dist = 0
# profile
profile 1
set mc_p_pitch = 70
set mc_i_pitch = 15
set mc_d_pitch = 60
set mc_p_roll = 70
set mc_i_roll = 15
set mc_d_roll = 60
set mc_p_yaw = 95
set mc_i_yaw = 45
set mc_d_yaw = 0
set mc_p_level = 20
set mc_i_level = 15
set mc_d_level = 75
set fw_p_pitch = 5
set fw_i_pitch = 7
set fw_ff_pitch = 50
set fw_p_roll = 5
set fw_i_roll = 7
set fw_ff_roll = 50
set fw_p_yaw = 6
set fw_i_yaw = 10
set fw_ff_yaw = 60
set fw_p_level = 20
set fw_i_level = 5
set fw_d_level = 75
set max_angle_inclination_rll = 300
set max_angle_inclination_pit = 300
set dterm_lpf_hz = 40
set yaw_lpf_hz = 30
set dterm_setpoint_weight =  0.000
set fw_iterm_throw_limit = 165
set fw_reference_airspeed =  1000.000
set fw_turn_assist_yaw_gain =  1.000
set dterm_notch_hz = 0
set dterm_notch_cutoff = 1
set pidsum_limit = 500
set yaw_p_limit = 300
set iterm_ignore_threshold = 200
set yaw_iterm_ignore_threshold = 50
set rate_accel_limit_roll_pitch = 2400
set rate_accel_limit_yaw = 360
set heading_hold_rate_limit = 30
set nav_mc_pos_z_p = 50
set nav_mc_pos_z_i = 0
set nav_mc_pos_z_d = 0
set nav_mc_vel_z_p = 100
set nav_mc_vel_z_i = 50
set nav_mc_vel_z_d = 10
set nav_mc_pos_xy_p = 65
set nav_mc_pos_xy_i = 120
set nav_mc_pos_xy_d = 10
set nav_mc_vel_xy_p = 180
set nav_mc_vel_xy_i = 15
set nav_mc_vel_xy_d = 100
set nav_fw_pos_z_p = 50
set nav_fw_pos_z_i = 0
set nav_fw_pos_z_d = 0
set nav_fw_pos_xy_p = 75
set nav_fw_pos_xy_i = 5
set nav_fw_pos_xy_d = 8
set rc_expo = 70
set rc_yaw_expo = 20
set thr_mid = 50
set thr_expo = 0
set roll_rate = 40
set pitch_rate = 40
set yaw_rate = 20
set tpa_rate = 0
set tpa_breakpoint = 1500
blackbox log see attachment.
Any idea?
.zip   blackbox_log_2017-10-01_170916.zip (Size: 410.9 KB / Downloads: 331)
While I look at your log, please edit your post and add [ code ] [ /code ] tags (without the spaces after and before the square brackets).
You have quite a bit of D-term induced noise.
On roll:
[Image: Es59YLxl.png]
and pitch:
[Image: ve8w3AHl.png]
This noise is amplified by the high D-term and is what you're seeing on the motor traces:
[Image: ruHF4rjl.png]
Suggestions:
Reduce D (and maybe P as well) on both pitch and roll axes.
Change the filter setup in inav to enable the D-term filter at the frequency of the noise:
set dterm_notch_hz = 130
set dterm_notch_cutoff = 60
There's also a second noise peak at about 260Hz. You could change the first gyro notch to deal with that by
set gyro_notch1_hz = 260
set gyro_notch1_cutoff = 180
Oh, and welcome to the forum!
  • fftunes
+1 to everything what unseen said, just personally i'd first try 130/110 or 130/100 instead of 130/60 (the wider, the more delay, more so at low frequencies).
Tbh i don't ever use notch filters below ~140Hz at all, in my experience it made propwash a lot worse...
  • unseen
(01-Oct-2017, 10:24 PM)fftunes Wrote: +1 to everything what unseen said, just personally i'd first try 130/110 or 130/100 instead of 130/60 (the wider, the more delay, more so at low frequencies).
I completely agree. The less filters, the better!
Seeing as this build is a 1.2Kg F450 and already has notch 2 down at 85/43, I doubt if moving notch 1 from 170/125 will make much difference to how it handles though.
  • fftunes
I am really surprised! I did not expect to get such a qualified feedback. I will try the suggestions as fast as possible.
[-] The following 1 user Likes Markus's post:
  • unseen
Try my suggestions before you thank me, I might not know what I'm talking about! Wink
Summarized, I have to change these parameters:
set gyro_notch1_hz = from 170 to 260
set gyro_notch1_cutoff = from 125 to 180
set dterm_notch_hz = from 0 to 130
set dterm_notch_cutoff = from 1 to 60
Right? I will test it when it stops raining...
Exactly so.
Please let us know how it went and post the log from the flight as well.
Here is the dump (just to be sure that I did change the right parameters):
# dump
# resources
# mixer
mixer QUADX
# servo
# servo mix
smix reset
feature -VBAT
feature -DASHBOARD
feature -BLACKBOX
feature -AIRMODE
feature -SUPEREXPO
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -OSD
feature VBAT
feature RX_SERIAL
feature GPS
feature BLACKBOX
# beeper
beeper HW_FAILURE
beeper RX_LOST
beeper DISARMING
beeper ARMING
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACTION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper LAUNCH_MODE
# map
map AETR1234
# name
name -
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
aux 0 0 0 1500 2100
aux 1 1 0 1500 2100
aux 2 2 0 1500 2100
aux 3 3 5 1500 2100
aux 4 9 1 1300 1700
aux 5 8 1 900 1300
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# master
set looptime = 2000
set gyro_sync = ON
set acc_lpf_hz = 10
set acczero_x = 167
set acczero_y = 3
set magzero_x = -18
set magzero_y = -25
set magzero_z = -70
set rssi_scale = 30
set imu_dcm_ki = 50
set deadband = 5
set stats = OFF
# profile
profile 1
set mc_p_pitch = 70
set mc_i_pitch = 15
set mc_d_pitch = 60
set mc_p_roll = 70
set mc_i_roll = 15
set mc_d_roll = 60
set mc_p_yaw = 95
set mc_i_yaw = 45
set mc_d_yaw = 0
set mc_p_level = 20
set mc_i_level = 15
set mc_d_level = 75
set fw_p_pitch = 5
set fw_i_pitch = 7
set fw_p_roll = 5
set fw_i_roll = 7
set fw_ff_roll = 50
set fw_p_yaw = 6
set fw_i_yaw = 10
set fw_ff_yaw = 60
set fw_p_level = 20
set fw_i_level = 5
set fw_d_level = 75
set yaw_lpf_hz = 30
set rc_expo = 70
set thr_mid = 50
set thr_expo = 0
set roll_rate = 40
set pitch_rate = 40
set yaw_rate = 20
set tpa_rate = 0
What is the feedback of the experts?
Should I also reduce P and D as mentioned in the first post?
set mc_p_pitch = 70
set mc_d_pitch = 60
set mc_p_roll = 70
set mc_d_roll = 60
.zip   blackbox_log_2017-10-03_123124.zip (Size: 550.75 KB / Downloads: 72)
(03-Oct-2017, 11:41 AM)Markus Wrote: Should I also reduce P and D as mentioned in the first post?
set mc_p_pitch = 70
set mc_d_pitch = 60
set mc_p_roll = 70
set mc_d_roll = 60
Yes, I think you should certainly reduce the D-term. If I look at what the defaults are in the preset for a quad with 10" props, I see that the default PIDs are:
80, 30, 18 Roll
80, 30, 18 Pitch
95, 45, 0 Yaw
Use the configurator to change the values rather than the CLI as I'm not sure which of the various CLI variables are the correct ones to change for PIDs in iNav.
I only had time to have a very quick look at your new log, but I'll do a proper comparison between this log and your first one later on.
Meanwhile I build up a hexacopter ATG650 X6 16. I reduced the D-term low pass to 5Hz:
set dterm_lpf_hz = 5
Therefore I was able to keep also P an D on a high level:
set mc_p_pitch = 70
set mc_i_pitch = 10
set mc_d_pitch = 50
set mc_p_roll = 70
set mc_i_roll = 10
set mc_d_roll = 50
The hexacopter is flying quite well, even in stronger wind.
  Betaflight Motor Test Results in SmokeStopper overvoltage LoganFPV 5 233 01-Aug-2023, 11:22 AM
  Build T-Motor F7 stack - Betaflight Gyro update frequency 3.2kHz ???? MindBenderFPV 2 3,081 18-Jun-2022, 09:10 AM
  GPS and motor bell fault after a crash Trial4life42 1 374 12-Apr-2022, 11:43 PM
Last Post: kafie1980
  Help List of motor size/KV for different props size / LiPo cell count Oscar 6 2,080 24-Mar-2021, 01:39 PM
Last Post: Titanv11
  Help Brushless motor or ESC broken? Not working properly after full throttle Niujaus 5 8,214 30-Apr-2019, 12:27 PM
Last Post: Drone0fPrey
