Just heard Connex is releasing a new FPV system we have been waiting a long time for: HD (high definition), low latency (they claim "zero latency" but i think that's just marketing), and allow more people to fly at the same time.
Traditional 2.4Ghz and 5.8Ghz we have been using for FPV have been great because of the cheap price and small size, however they suffer from limitation on the number of pilots that can fly at the same time, too many VTX powered on the same time can cause video interference. Latency is low but definitely should be improved. Another thing is the video quality is not really that good compared to the recording cameras we normally use.
The new Connex HD FPV system provides pretty decent video quality for real time FPV, I would say comparable to the Mobius footage. It will also allow many more pilots to fly at the same time. Price is not confirmed yet.
Release date is 10th May 2016.
Features:
More info about this:
Product Name: Connex ProSight
It looks like the Connex ProSight consists of 3 components: Camera, VTX and VRX:
Delay-Free FPv HD camera, The CONNEX ProSight HD camera is optimized for both indoor & outdoor flights, featuring advanced High-Dynamic-Range sensor, allowing 720P delay-free crystal clear video
Delay-Free HD Transmitter The CONNEX ProSight transmitter supports delay- free uncompressed all-digital HD transmission. Optimized for multi-pilot FPV Racing, providing fully immersive flight experience
Robust Digital HD Receiver The CONNEX ProSight ground receiver unit provides a robust digital link over the 5GHz band. Its HDMI interface, compatible with all popular HDMI goggles & screens in the market.
Here is the official list of Features:
Specifications Transmitter Unit:
Specifications Camera:
Features:
- Solid digital link
- Fly simultaneously with up to twice as many pilots as analog FPV
- Record on-board HD without the need of a secondary camera like a GoPro
- Low latency 60fps video and transmission (near 0, under 1ms)
- Some other features not revealed yet until release
- 720p30 HD Camera, with high-dynamic range sensor and 2.8mm lens
- Receiver Unit outputs standard 720p60 over HDMI for reducing motion blur
- Compatible with all popular HDMI based Goggles/Monitor
- Digitally paired transmitter to receiver for crosstalk-free flight
- Supported LOS range of 100ft to 3000ft (300m to 1000m) varies with field conditions
- Advanced frequency setup for multi-pilots: Automatic & Manual modes, supporting 27 digital channels (FCC)
- System configuration via Bluetooth using Android/iOS app or through built-in on-screen display menu
- Advanced High Definition spectator viewing mode
- Camera to HDMI receiver-out maximum latency of 26mS
- Dimensions: 70x36.5x7.2mm
- Weight: 32gr
- Input voltage: 8v – 16v (supports 2S to 4S)
- Power Connector: 4 Pins
- Power Consumption: 4.1W
- Antenna Connector: 2 External MMCX Connectors
- Video Interface: MIPI
- SW Upgrade: Micro USB
- Product Configuration: Mobile App over Bluetooth
- Dimensions: 75x115x17mm
- Weight: 134gr
- Input voltage: 8v – 26v (supports 2S to 6S)
- Power Connector: DC Jack
- Power Consumption: 3.5W
- Antenna Connector: 5 SMA Connectors
- Video Interface: HDMI (Type A)
- Dimensions: 28x20x27mm
- Weight: 13gr
- Input voltage: 5v from Transmitter
- Power Connector: MIPI
- Power Consumption: 1W
- Antenna Connector: N/A
- SW Upgrade: Through Transmitter
- Product Configuration: Via On-Screen Display
