Connect an OSD on camera AIO
The AIO cameras, are those little cameras that come with a fixed video transmitter to the back of the camera.
It is impossible to look to get your video signal in order to superimpose the OSD. Well in this case it is possible!
We'll show you how.
Necessary material :
  1. An EF-01 type camera
  2. A flight map with OSD
It must first isolate where passes the video signal on the AIO.
In this case, it comes to the more PIN above, aim left.
You will need to remove this junction to the first using your soldering iron by melting the plastic, and then, using a cutter.
Then comes the solder a piece of wire on the VTX and another end of the cable to the camera.
It remains for you to connect your cables VIN and VOUT your card to make a test before the clean.
Video
good mod [Image: 1f609.svg]
https://pimousse.be/ Belgian FPV & Aeromodelism
[-] The following 2 users Like Pimousse's post:
  • hugnosed_bat, sloscotty
  Help OSD Working but Grey Screen Caelus_fpv 4 120 Yesterday, 03:14 PM
Last Post: Caelus_fpv
  Betaflight OSD not showing any information, but OSD menu is working gwennoyel 22 9,235 19-Apr-2024, 08:35 PM
Last Post: Maxym666
  Help OSD Not Displaying Victory FPV 11 533 20-Mar-2024, 11:43 AM
Last Post: Victory FPV
  Black video but with OSD Dexter 6 252 08-Mar-2024, 10:42 AM
Last Post: Dexter
  Black screen and no OSD: Eachine TX06 + EV800 + DarwinFPV F411 Ultralight/Whoop AIO aprudnikoff 1 156 05-Mar-2024, 09:18 PM
