Configuration for New ESC
Hey guys, I bought these LittleBee ESCs. Is there any configuration needed or do I just solder the motors (swap 2 wires on two for ccw) and fly?
http://www.banggood.com/4X-Favourite-FVT...70787.html
Love it when someone called Charpu asking question in Beginners section Smile Just kidding!!
Generally that should be sufficient. Confirm motor direction before you put props. These are mutishot capable so select it if your FC supports it.
unless you want to use BLHeli to change it you can do that also.
[-] The following 1 user Likes OverDischarged's post:
  • tashu.cristy
Normally i reflash then through the FC immediately after installing with the latest blheli then set damped light and the min to 1040 and max to 1980.
Then set also the fc to the same in beta / clean flight. Finally check whether all of them are in synch with the others regarding their settings
I used them on a micro build with 3800KV motors - no problems. I left the default firmware (I think it was 14.6) and just changed motor timing to high and reversed the direction on two of my motors (as opposed to crossing the wires) They have flown great, motors are smooth and no desyncs.
The next build will be perfect! | Fleet and build info | YouTube Channel |
Or if you don't care, you can just solder them in their places (swap the wires when needed) and fly, in 99% of the cases they will just work.
Question Is it possible to test if an ESC works without soldering? HypnoToad 2 130 23-Mar-2024, 07:22 PM
Last Post: HypnoToad
Exclamation Noob Question..... "VTX/ESC" Boards.... Coleon 12 333 02-Mar-2024, 12:35 PM
Last Post: Luk5569
Exclamation SpeedyBee F7 ESC Question... Coleon 6 404 30-Jan-2024, 07:05 AM
Last Post: Coleon
  SpeedyBee F7/ESC Cap Question.. Coleon 5 331 27-Jan-2024, 10:07 PM
Last Post: Coleon
  bidirection DSHOT VS TELEMETRY ESC Eyes.fpv 1 231 25-Jan-2024, 05:28 AM
Last Post: V-22
