So this is going to be my first ever quadcopter build and while I was choosing the motors I came across threading.
So the motors I wanted to use (Racerstar 2212 1400kv) come with the collet adapter which I don't think are good enough.
Where as the prop adapter I wanted to use i.e. bolt-on prop adapter, couldn't be attached from those Racerstar.
Only 2205 and 2206 and above have those integrated Bolton prop adapter but they are too expensive for me.
My questions are~
1- Is there any motor that comes with or supports Bolton prop adapter but is not too expensive?
2- is there a way to use Bolton prop adapter on the Racerstar 2212 brushless motors instead of the collet prop adapter which they come with?
3- are the collet prop adapter good enough for an acrobatic Quadcopter?
_____________________________________________________
Edit~ My Quadcopter specs:-)
•330mm frame
•BR2212 Racerstar motor
•20a Racerstar v2 lite ESCs
•Omnibus f4 AIO
•3s Li-Po battery
•8045 Carbon fiber propellers
•flysky i6 receiver and transmitter
My questions are~
•330mm frame
•Omnibus f4 AIO
•3s Li-Po battery
