CLI Dump for DarwinFPV BabyApe II 3.5inch
Full review: https://oscarliang.com/darwinfpv-babyape-ii/
defaults nosave
# Betaflight / STM32F411 (S411) 4.3.2 Nov 28 2022 / 07:27:10 (60c9521) MSP API: 1.44
# config: manufacturer_id: DAFP, board_name: DARWINF411, version: bff306ae, date: 2022-11-15T12:36:53Z
# start the command batch
batch start
defaults nosave
board_name DARWINF411
manufacturer_id DAFP
mcu_id 003c00133132510f30313835
signature
# name: DarwinFPV
# beacon
beacon RX_LOST
beacon RX_SET
aux 0 0 0 1300 2100 0 0
aux 1 1 0 1300 2100 0 0
aux 2 13 1 1700 2100 0 0
aux 3 35 1 1300 1700 0 0
# vtxtable
vtxtable bands 6
vtxtable channels 8
vtxtable band 3 BOSCAM_E E FACTORY 5705 5685 5665    0 5885 5905    0    0
vtxtable band 6 IMD6     I CUSTOM  5732 5765 5828 5840 5866 5740    0    0
vtxtable powerlevels 4
vtxtable powervalues 0 1 2 3
vtxtable powerlabels 25 200 400 600
# master
set gyro_lpf1_static_hz = 375
set gyro_lpf2_static_hz = 750
set dyn_notch_count = 2
set dyn_notch_min_hz = 100
set dyn_notch_max_hz = 1000
set gyro_lpf1_dyn_min_hz = 375
set gyro_lpf1_dyn_max_hz = 750
set acc_calibration = 28,-76,-93,1
set mag_hardware = NONE
set baro_hardware = NONE
set blackbox_sample_rate = 1/8
set dshot_bidir = ON
set motor_output_reordering = 3,2,1,0,4,5,6,7
set current_meter = NONE
set simplified_gyro_filter_multiplier = 150
set osd_vbat_pos = 2455
set osd_link_quality_pos = 2082
set osd_tim_2_pos = 2433
set osd_flymode_pos = 2105
set osd_throttle_pos = 2401
set osd_crosshairs_pos = 2253
set osd_craft_name_pos = 2442
set osd_altitude_pos = 66
set osd_avg_cell_voltage_pos = 2423
set osd_nheading_pos = 333
set osd_flip_arrow_pos = 2222
set vtx_band = 4
set vtx_channel = 8
set vtx_power = 4
set vtx_freq = 5880
set gyro_1_sensor_align = CW270FLIP
set gyro_1_align_yaw = 2700
set rpm_filter_harmonics = 2
set name = DarwinFPV
# profile 0
set vbat_sag_compensation = 100
set anti_gravity_gain = 10000
set iterm_relax_cutoff = 10
set i_pitch = 88
set d_pitch = 63
set i_roll = 84
set d_roll = 55
set i_yaw = 84
set d_min_roll = 40
set d_min_pitch = 45
set thrust_linear = 20
set dyn_idle_min_rpm = 35
set simplified_i_gain = 105
set simplified_d_gain = 135
set simplified_dmax_gain = 110
profile 1
profile 2
rateprofile 1
rateprofile 2
rateprofile 3
rateprofile 4
rateprofile 5
# save configuration
  CLI dump for the GEPRC Cinebot25 S Oscar 0 122 09-May-2024, 11:53 PM
Last Post: Oscar
  CLI dump for Caddx GoFilm20 Cinewhoop (walksnail moonlight) Oscar 2 227 26-Apr-2024, 10:34 PM
Last Post: Oscar
  CLI Dump for HGLRC Drashark 1S 1.6inch Micro Quad Oscar 1 664 23-Apr-2024, 08:08 PM
Last Post: segler999
  Data CLI dump for TMOTOR 13A F411 AIO ph2t 3 935 03-Apr-2024, 06:03 AM
Last Post: ph2t
Question Anyone got a GepRC Darkstar 20? Backup Cli? alvestadkristian 3 245 11-Feb-2024, 09:49 PM
