27-Mar-2017, 07:02 PM
One other thing, just in case it was overlooked - make sure the battery has been fully charged.
clean flight hook up |
27-Mar-2017, 07:02 PM One other thing, just in case it was overlooked - make sure the battery has been fully charged. Here is a photo of the back and of it plugged in the usb. The green light is flashing, if that means anything. 28-Mar-2017, 04:37 PM And you still get nothing when a freshly charged battery is plugged in? If not, check the pins where the battery plugs in. Sometimes one of those flat pins on the connector can get flattened against the housing, missing the battery connection completely (I've had that happen). Look at it carefully as you plug in the battery. 28-Mar-2017, 05:27 PM Nope, nothing happens. I looked at the pins and they look good. They are sliding in the battery connector ok. 29-Mar-2017, 12:40 AM We tried another battery and nothing. I think we have bad luck. THanks for your help, we appreciate it. |
After 1-2 minutues of flight, drone flips over in air | doublebubble | 22 | 714 | 16-Feb-2024, 11:32 PM Last Post: mstc | |
Basic Autonomous flight | T_Jennings | 2 | 170 | 04-Feb-2024, 10:26 PM Last Post: mstc | |
No input from reciver on my flight controller | Horbalisk | 0 | 185 | 17-Jan-2024, 07:17 PM Last Post: Horbalisk | |
Flight controller not recognizing CRSF in betaflight | SenaFPV | 10 | 535 | 15-Jan-2024, 09:03 AM Last Post: SnowLeopardFPV | |
Roll reverse in flight | MSIOU | 12 | 1,778 | 30-Dec-2023, 05:27 PM Last Post: segler999 |
