20-Jan-2017, 12:48 PM
Can anyone tell me how to check for a shorted or broken winding in a brushless motor. I crashed and have a stuttering motor now and want to be sure it's a motor issue before I replace the ESC
Check for Shorted brushless motor winding |
20-Jan-2017, 12:48 PM Can anyone tell me how to check for a shorted or broken winding in a brushless motor. I crashed and have a stuttering motor now and want to be sure it's a motor issue before I replace the ESC 20-Jan-2017, 12:51 PM Resistance across each wire, anything unusual, ground. Also check your signal output connections in your fc 20-Jan-2017, 01:11 PM Do you use bullet connectors? 20-Jan-2017, 02:20 PM 20-Jan-2017, 04:35 PM I think he mean the frame of the motor, if you measure zero ohm then you know that you have a damaged winding. 20-Jan-2017, 05:10 PM Windings have very small resistance which most multimeters can't measure, it will show 0 between two phases for both a good and a fried motor. If you have a winding short to stator you have to measure between motor wires and the stator, which is generally not accessible for a multimeter probe. |
PWM circuit for a motor testing rig | Pathfinder075 | 10 | 131 | Yesterday, 04:44 AM Last Post: skywanderer | |
Recursion Labs - Sub 250g Motor and Propeller Testing | Recursion | 36 | 4,670 | 21-Mar-2024, 07:02 PM Last Post: skywanderer | |
Help ESC working but motor not spinning | Prashant1901 | 1 | 107 | 10-Mar-2024, 02:09 AM Last Post: Pathfinder075 | |
Motor or ESC ? | Flybyjim | 4 | 152 | 13-Feb-2024, 12:31 AM Last Post: Flybyjim | |
Tip & Trick Staggered motor wire joining, way neater. | ph2t | 2 | 482 | 28-Jan-2024, 05:31 PM Last Post: mstc |
