Threads: 672
Likes Given: 2,027
139 09-Jun-2017, 12:44 AM (This post was last modified: 09-Jun-2017, 12:45 AM by Oscar.) Does this help?
I don't know your chargers... don't they have "normal charge" mode? where you just need to plug in the main lead without the balance lead? You just need to charge it like a normal 2S lipo battery.
The Fatshark batteries has "self balancing" circuit built-in so balance lead is not needed in charging.
Threads: 36
Likes Received: 83 in 46 posts
Likes Given: 124
4 No my charger appears to require that the balance lead be plugged in as well or it doesn't work.
Quads: RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3
YouTube - Mr.E_fPv
Threads: 36
Likes Given: 124
4 09-Jun-2017, 01:59 PM (This post was last modified: 09-Jun-2017, 01:59 PM by rryyyaann.) Checking the voltage with a multi-meter it seems hooking it to the SkyRC charger is doing something. It got up from 7.8 volts to 9. Which is too high for a 2s 1800mah battery. The led indicator in the battery isnt showing any increase in charge.
I really dont want to buy a new charger just to charge this battery.
YouTube - Mr.E_fPv
Threads: 3
Likes Received: 10 in 8 posts
Likes Given: 7
0 09-Jun-2017, 02:07 PM (This post was last modified: 09-Jun-2017, 02:08 PM by Kleinerbug_FPV.) some charger require to also have the Balance lead connected even if you are just doing a regular Charge. I had the same Problem with my Accucell 6 (80Watt) charger and needed to do a Firmware update to solve the Problem. I think there is nothing else that you can do then buying a new charger that is capable of charging the FS Lipo. Or go for the 18650 case…much better!
- Kleinerbug_FPV
Quad Garage: 1x KISSed QAV 210 on RS2205, 1x Betaflight ARC 200 on RS2205, 1x whooped FuriBee F36
Threads: 36
Likes Given: 124
4 Guys I found a work around. My charger requires I have a balance lead plugged in. So I used the FatShark banana to charge the FS battery then hooked up a separate 2200mah 2s to the balance port. This worked, it is charging the FS battery.
It should be noted, I did this method for 15 mins in a lipo safe inside a metal tool box. Neither battery got hot after 15 and everything seemed good. I can't guarantee safety here but it does work.
YouTube - Mr.E_fPv
Threads: 672
Likes Given: 2,027
139 To be honest i don't even use the battery that comes with the Goggles... i get a 2000mah 2S pack and it lasts at least 3 times as long than the original pack..
Some people even get the 4000mah pack designed for the Specktrum TX... but it's quite expensive.
