05-Sep-2016, 04:20 PM
This is probably the largest brushed motor in terms of size that is suitable for brushed micro quad I have seen.
This is strictly for 1S (not 2S compatible). It should provide extra power than the 0820, but due to the larger motor width this requires some frame modifications.
http://www.banggood.com/Chaoli-CL-1020-1...84263.html
Spec
Spec
- Motor Diameter: 10mm
- Motor Length: 20mm
- Shaft Diameter: 1.0mm
- Cable Length: 60mm
- Weight: about: 7.5g
- Rated voltage 3.7V DC
- Operating voltage range DC1.5-4.5V DC
- No Load 46000r/min
