Changing esc khz
Just wondering how I change my esc khz?
I've got a sp racing evo on 2.8 betaflight and it's at 8khz looptime. But I don't know how to set the esc khz. I've installed the latest multishot blheli firmware on my Xm20a esc's.
How to I try 4khz and 8khz?
Thanks for any info.
I've done some more searching and while I haven't found a 'how to' I've click commands for 'motor pwm' settings. I'm assuming changing it from the default 400 to 4000 will give the esc's a 4k signal.
Can anyone confirm that I would be doing the right thing?
(03-Jun-2016, 09:22 PM)Nunks Wrote: I've done some more searching and while I haven't found a 'how to' I've click commands for 'motor pwm' settings. I'm assuming changing it from the default 400 to 4000 will give the esc's a 4k signal.
Nope.  Setting motor_pwm_rate above 500 will switch to brushed motor mode.
See: https://github.com/cleanflight/cleanflig...ocs/Cli.md
I think to do what you want, you will have to do through BLHeli (if that's the type of esc you have).
Ah OK thanks. After a bit of playing around with gyro and PID sync denom settings it seems I can only get this fc up to 4k/4k. The esc beeps go out of sync as soon as I try for 8k even with another of stuff turned off.
I found a bit on the betaflight wiki stating that the PID rate is the motor/esc update rate. So I've found my answer. This newbie just learnt one more thing today.
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 240 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 112 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 138 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 213 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 140 10-Mar-2024, 02:09 AM
