Threads: 7
Likes Received: 0 in 0 posts
0 Just wondering how I change my esc khz?
I've got a sp racing evo on 2.8 betaflight and it's at 8khz looptime. But I don't know how to set the esc khz. I've installed the latest multishot blheli firmware on my Xm20a esc's.
How to I try 4khz and 8khz?
Thanks for any info.
Threads: 7
0 I've done some more searching and while I haven't found a 'how to' I've click commands for 'motor pwm' settings. I'm assuming changing it from the default 400 to 4000 will give the esc's a 4k signal.
Can anyone confirm that I would be doing the right thing?
Threads: 7
0 Ah OK thanks. After a bit of playing around with gyro and PID sync denom settings it seems I can only get this fc up to 4k/4k. The esc beeps go out of sync as soon as I try for 8k even with another of stuff turned off.
I found a bit on the betaflight wiki stating that the PID rate is the motor/esc update rate. So I've found my answer. This newbie just learnt one more thing today.
