Chaaaaaaarging!
Back yet again! Have done a bit of light research on the topic, but was just curious what you all run. I have an iMax B6, and charge either one 4S @ 0.8A, or five 4S on a parallel board @ 1.8A. I am getting a new ISDT Q6 in, and am curious what amperage you all push on your batteries? I always want to keep it safe, and never harm the batteries, so I have always tried to keep it low. Thoughts?  Big Grin
I normally charge batteries at 1C, but if I'm in a hurry, I'll charge them at 2C.
I use an ISDT Q6+ with a 350W psu and if I were to charge a single 4S 1300 mAh I would use 1.3 amps, when I use a parallel board for the same capacity of batteries I use 1.3 amps per battery. 2C should be fine but I find I am usually not in a rush and like to baby my batteries. Also I always use 1C for my goggle batteries.
Flying: Talon SVX 220 Hypebuild! & WATERPROOF Martian 3, 5" Motors: Hyperlite 2205 2522Kv FC: DYS F4 Pro (BF Omnibus F4 3.2.0) ESC: Speedix ES20 Lite (potted in 2 part epoxy) VTx: Tramp HV (conformal coated) Rx: Crossfire micro V2 (conformal coated) Camera: Runcam Eagle 2
(24-Dec-2017, 10:01 AM)unseen Wrote: I normally charge batteries at 1C, but if I'm in a hurry, I'll charge them at 2C.
Ever run into any issues with that?
(24-Dec-2017, 06:44 PM)McDee Wrote: I use an ISDT Q6+ with a 350W psu and if I were to charge a single 4S 1300 mAh I would use 1.3 amps, when I use a parallel board for the same capacity of batteries I use 1.3 amps per battery. 2C should be fine but I find I am usually not in a rush and like to baby my batteries. Also I always use 1C for my goggle batteries.
Nice! How do you like that charger btw?
I'm very happy with it! I am planning on getting a voltage reference to calibrate it however. They are not perfect from the factory, though pretty close I hear.
I just think it's worth the time to make it as good as possible to max the battery life. Joshua Bardwell did two good videos recently on calibrating these chargers.
I have a few ISDT, great charger. I have a few PSU from old computers I savaged. I usually charge at 1C in parallel.
(24-Dec-2017, 11:12 PM)voodoo614 Wrote:  I have a few PSU from old computers I savaged.
I savage computers too!
Lmao!
(24-Dec-2017, 07:14 PM)s3npai Wrote: Ever run into any issues with that?
Nah. Check the specs for your batteries. Some are quite happy to be charged at 5C. It all depends on the battery.
Imax b6
A wee bit inexperienced here but b6 doesn't let you charge at the wrong rate..also bought life battery for taranis q x7 and the Imax b6 supports its charging mode
Imax b6 allows amp control. It charges at any rate you want up to 50W max.
iSDT SC200 here Smile
I only parallel charge 2 packs at once, @ 2C, e.g. for 4S 1500mah packs i use 6A current.
I can charge more packs at once, but I found it easier to match the voltages in pairs, and easier to handle if there is a problem.
  • s3npai
I always return my packs to storage charge after a day's flying.
That way i can be sure that they are all close enough so that I can charge six at a time in the morning on 1C. Having six batteries ready to go after 45 minutes is a great time saver.
  • s3npai
I usually storage charge mismatch lipos and then parallel charge. I find that I am more consistent when I land that the lipos are in the general voltage.
[-] The following 2 users Like voodoo614's post:
  • unseen, s3npai
#15
Oscar Wrote:I can charge more packs at once, but I found it easier to match the voltages in pairs, and easier to handle if there is a problem.
unseen Wrote:I always return my packs to storage charge after a day's flying.
voodoo614 Wrote:I usually storage charge mismatch lipos and then parallel charge.
Probably some of the best tips I have encountered yet!! I have always wondered about doing that, but hesitated to do so. Now that I am looking at the ISDT, I wonder, for the extra price of this setup, is it really worth it. I still need to get a decent power supply to run the thing, which is pretty big and loud.
On a side note, have any of you tried the "current sensor calibration" through betaflight? I was thinking of giving it a shot here soon and was just curious.
