14-Apr-2016, 08:52 AM
Unless stated Otherwise, All Frames and parts are all purchased with my own monies and I am not paid to make any endorsements or recommendations for a particular product, I just share my views on the subject matter.
Thought I would share my views on the Speed Addict 210-R FPV Racing Frame from Catalystmachineworks.
I went for the 4mm heavy duty version along with the added optional extra Gopro and Gopro session HD mounts.
This Frame is superb, The quality is simply amazing and the attention to detail is second to none.
The 4mm Kit comes with everything you need in terms of hardware for the frame to be built, you will of course need to supply all your own electronics .
Small things like blue anodised screws for the whole frame, including motor screws is a really nice touch.As is the FPV camera bracket and 3D mount , Ninja Flex RX holder. Also comes with RX antenna tubing.
The Carbon fibre is simply a sight to behold, beautifully finished and did not require any sanding on my part to make parts fit.
The frame is designed for certain pieces of hardware to give it that completed look ,as though everything is meant to be there not just stuck inside. Not only that but board cams will not fit, nor will a full size VTX.
It is worth noting that your electronic hardware needs to similar to the following.
1. PDB, I used The PDB as recommended by catalystworkmachines .The correct type of PDB is very important as the Battery cable needs to come out of the RHS of the frame and as such requires the Battery Pinout on the PDB to face that side, as well as the ESC pads facing front and rear of the frame. For those that do not want to look for the board, here is. http://www.catalystmachineworks.com/coll...racing-pdb
2. A small VTX is also a requirement, I used the small Hawkeye vtx and fits perfectly, and I believe is recommended by catalystmachineworks. http://www.catalystmachineworks.com/coll...w-raceband
3. A HS1177 FPV camera is a must as the 3d bracket is designed for that particular camera. http://www.catalystmachineworks.com/coll...fpv-camera
4. Motors and esc's are your choice and so long as the esc's fit on the arms and still clearance for the PDB enclosure nuts on the top plate you will be fine. This is all noted in the detailed build manual available online.
5. TX: again, this is something that needs to fit in the small areas of this frame and as such, anything like the Frsky D4R, X4R-SB and TFR4-SbB will fit easily and pretty much what the RX antenna holder is made for.
I recommend doing a dry build on this frame before you commit to cutting wires etc, as you really have to make this a super clean build, and excess wires will get in the way and of course will make the whole thing look messy.
The actual build does take some time as you have to solder pretty much everything with the PDB attached to the frame, and The PDB sits below the bottom plate in a kind a of PDB enclosure, which by the way also acts as a good flat platform to land on.
If you are not comfortable cutting wires and doing direct soldering to the PDB and Flight controller then this frame is probably not right for you, unless you can bribe a mate to build it for you.
There are really no hidden danger/warning areas that will catch you out so long as you follow the manual ,Very Important you do that.
My Hardware Specs:
Emax 2205 2300kV Red Bottom motors
DYS XM20A v1 ESC's
HS1177 FPV Cam
Hawkeye 200 mW VTX
ATAS PDB
SPRacing F3 flight controller
DAL TJ5045 Triple Props.
1300mAh 4S Bonka, Tattu Lipos
My AUW as you see it in the pics is 617 grams.
Here are a couple of completed build Pics.
I enjoy building, but have to say this was one of the most rewarding.
Running Betaflight 2.6.1
Airmode
Luxfloat
Test flight and hovering completed just waiting to do a proper FPV flight and tweaking the PIDs somewhat.
I highly recommend this frame in terms of quality, I cannot vouch for it's performance as yet, but if it fly's as good it looks I am sure it will be Awesome.
Check out CatalystWorkmachines here: http://www.catalystmachineworks.com/
I will post flight video once I have tuned to my liking and got a couple of good flights in.
My Hardware Specs:
DYS XM20A v1 ESC's
HS1177 FPV Cam
Hawkeye 200 mW VTX
ATAS PDB
Airmode
Luxfloat
