Threads: 9
Likes Received: 5 in 3 posts
2 Hello everyone,
I amp building a 10" quad and using the AIKON 8IN1 ESC. It comes with two 50V 470uf capacitors but I am afraid it won't be enough?
I use 2200uf 35V on my 5" quads with 6S batteries...
What would you recommend? 4700uf ?
Best
Threads: 4
Likes Received: 62 in 57 posts
Likes Given: 17
8 i'd probably run a single bigger cap, or what some do is put smaller caps (these 470uf's could work) between each ESC lead rather than (or in addition to) the battery lead having a cap.
Threads: 9
2 Thanks. If you were to go with a single bigger cap, what would you use?
Threads: 1
Likes Received: 11 in 11 posts
Likes Given: 1
1 on 8s builds I'd go higher with the volts. use a 50V. I never put anything below 1'000uF on it and i recommend you use good quality. the best i've seen so far are the japanese Rubycon
