Cant arm quad when telemetry via softserial activated
Hey Guys!
first of all i would like to thank Oscar for an awesome blog filled with info!
My setup is: Latest Betaflight, Naze32 Rev5, Taranis x9d Plus and X4R reciver with the sbus hack.
It´s working fine with sbus, im arming the quad with a switch on aux2, and when im setting up the telemetry everything works fine, i can see all the sensors, im getting the info to the taranis, but i cant arm it? im checking Modes in bf, everything looks fine, but the Arm box wont turn green when i flip the switch, and the values are all fine (like before softserial) and i cant arm via sticks either..
Minimum Throttle and minimum command are also ok.
Am i missing something?
Attached Files Thumbnail(s)
is the LED flashing on the board or dead solid?
do you have ACC enabled? try calibrate it as well?
(04-Feb-2016, 12:38 AM)Oscar Wrote: is the LED flashing on the board or dead solid?
Blue Led is solid, red led is flashing, i think i have ACC enabled, i havent disabled it manually, and it´s calibrated before, ill check that later..  i read something about you can get poor/almost no reception if the quad and transmitter are close together, ill have a look at that also later this evening
yes, the close signal lost is a bug in X4R.
(05-Feb-2016, 12:12 AM)Oscar Wrote: yes, the close signal lost is a bug in X4R.
im gonna try it tonight, busy week Smile
What frame is that?
(05-Feb-2016, 11:56 AM)HamsterFPV Wrote: What frame is that?
sorry for late answer, Scorpia Legacy from Lizard RC
http://lizard-rc.se/index.php?id_product...&id_lang=2
Updating for knowledge, I had the Radio to close to the reciver and lost signal.
  Where to put 2.4GHz ELRS RX with ceramic antenna on 5in racing quad? Luk5569 6 167 05-Mar-2024, 12:54 PM
Last Post: ph2t
  Data Zombie Quad? Green_Weedle 2 139 05-Feb-2024, 10:27 PM
  How quad building has helped my Beer brewing Rob Axel 5 224 16-Oct-2023, 01:24 AM
  Help Find my quad aerokam 16 805 10-Oct-2023, 04:52 PM
Last Post: Dak_4008
  Broke my first quad, fixed my first quad FPVme 4 293 23-May-2023, 07:11 PM
Last Post: FPVme
