Can you change Naze32 SBUS port? 4 to 5 for example
Im wondering if there is a way to Change the Naze32 Sbus input port, from 4 TO 5?
had a little accident, and it seems like a waste to throw the naze in the bin..
nope, however you can use RX pin though on the top (if you do that, you will need to select serial RX in UART2 in port tab, and disconnect SBUS everytime you connect to USB)
Thanks!
put down a order for a new one.. Smile
  FC SBUS Out Rotems 2 276 18-Oct-2023, 09:00 PM
Last Post: Rotems
  Hd-Zero sbus on soft serial? Rob Axel 1 268 08-Aug-2023, 12:11 PM
Last Post: Pennywise
  FRsky r-xsr F-Port can't communicate with Mamba f722 Trackzero 3 661 07-Sep-2021, 11:15 AM
  FRsky F-Port not working r-xsr bffigjam 6 3,833 22-Mar-2019, 01:53 AM
  Help X4R-SB doesn't bind with Taranis SBUS Oscar 1 1,744 06-Nov-2017, 07:46 PM
Last Post: raspberrypi33
