Can Not config my SkyRC BLheli 12A ESC
Hallo
I got some older SkyRC BLheli 12A ESC (shuold be oneshot compatable) that I used in my build with Omnibus F4.
Some strange things are happening, when connecting with betaflight and using oneshot 125 or oneshot 42, I can only have the ESC beep when I hit save and reboot and then the engines start spinning 100 % immediatly (except one motor with a soldering issue I believe).
Tryed to connect in BLheli config, can connect but no reading.
Any idea what I need to do?
Samuel
Do they work using standard PWM while other settings are the same? If that works then it probably means those ESC doesn't support those protocols.
Maybe try to update the ESC firmware too.
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 247 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 112 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 139 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 215 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 143 10-Mar-2024, 02:09 AM
