Poll: Can I stabilize it with this conditions? :-)
You do not have permission to vote in this poll.
Yes
0%
0 0%
No
100.00%
1 100.00%
Total 1 vote(s) 100%
* You voted for this item. [Show Results]
Can I tune stabilizing mode without rate mode tested properly?
Hi guys, I am afraid of testing my quadrotor after tuning rate mode, that's so hard to hover with it in rate mode and I have broken many propelers and afraid of breaking my frame and motors too!!
My frame is Tarot sport 650.
I have tunned my rate PIDs with some videos and that works nice when I testing it in every axis...
Can I stop tuning rate PIDs and go to tune angle mode PIDs?
I am writing my own firmware with mega2560 and 100Hz loop, angle calculated with EKF, & using GY85 imu.
Thank you.
maybe, but very hard, as you cannot tell if the ACC or GYRO is causing problem if there is one.
  • soli_sal
Thank you for your response...
I know that gyro may drift or maybe its signal has a lot of noise because of oscillation, but what can occure with acc? what kind of problems do you mean?
I am using acc with EKF and with help of gyro the result is good for angle calculation, so the EKF works great on filtering its noise, does is necessary for filtering acc data too?
  Rate tuning B4tn 3 386 24-May-2023, 05:02 PM
Last Post: Rob3ddd
  Quad won't Arm Low Power Mode Unable to record videos Seanalami 3 547 27-Mar-2022, 11:13 PM
  TBS CROSSFIRE TX LITE is stuck in binding mode Seanalami 3 768 26-Mar-2022, 12:56 PM
Last Post: Seanalami
  Help Brushless motor or ESC broken? Not working properly after full throttle Niujaus 5 8,188 30-Apr-2019, 12:27 PM
Last Post: Drone0fPrey
  Discussion How to properly break a quad s3npai 5 1,070 01-Oct-2018, 06:10 PM
Last Post: s3npai
