Camera Switcher with betaflight
I have a minicube F3. Can I configure betaflight to output pwm on a pin to control a camera switcher(from switch on taranis)
Can the led pin be repurposed?
Other possibilities?
hi flightmode0 welcome to intoFPV!
What kind of camera switcher?
I only see 4 PWM outputs and I am guessing they're for the motors as usual. When looking at the board there is an RX2 and TX2... maybe UART2? Could you use that? I am not sure if that's where your receiver hooks up though, it appears that it may connect near the LEDs
This is the product I looked at for my answer. If yours is different then let us know.  https://www.banggood.com/de/Eachine-Mini...gL3JPD_BwE
carl.vegas
It depends on what kind of switching you need. Off the top of my head I can think of two ways to do what you want.
Using PWM, but unfortunately you don't have an extra one. With pwm you can get a micro pwm switch.
The other way would be to use a relay. Connect to beeper and change beeper tone to constant. So when you flip the beeper switch it, it switch the relay. But it also mean you have to remove all other beeper tone.
I have never tried these ideas, so take it as working ideas.
Thank you. This sees like a nice community.
http://www.micronwings.com/Products/FPVC...ndex.shtml
I'm rather new to RC electronic in general.
That looks promising. Only problem is you don't have an extra PWM output on your FC. You might be able to remap PWM 5 to the LED.
Is there anything hindering soldering directly to a MCU pin, even if has not been broken out on the board?
I think I need to do some reading on this.
This is what I get when I type in resource list in the CLI:
A00: ADC_BATT
A01: ADC_CURR
A02: MOTOR 4
A03: MOTOR 3
A04: MPU_CS
A05: SPI_SCK 1
A06: SPI_MISO 1
A07: SPI_MOSI 1
A08: FREE
A09: SERIAL_TX 1
A10: SERIAL_RX 1
A11: FREE
A12: FREE
A13: FREE
A14: FREE
A15: FREE
B00: FREE
B01: OSD_CS
B02: FREE
B03: LED 1
B04: PPM
B05: USB_DETECT
B06: I2C_SDA 1
B07: I2C_SCL 1
B08: MOTOR 1
B09: MOTOR 2
B10: FREE
B11: FREE
B12: SDCARD_CS
B13: SPI_SCK 2
B14: SPI_MISO 2
B15: SPI_MOSI 2
C13: MPU_EXTI
C14: SDCARD_DETECT
C15: BEEPER
F00: FREE
F01: FREE
F04: FREE
A00: ADC_BATT
A01: ADC_CURR
A02: MOTOR 4
A03: MOTOR 3
A04: MPU_CS
A05: SPI_SCK 1
A06: SPI_MISO 1
A07: SPI_MOSI 1
A08: FREE
A09: SERIAL_TX 1
A10: SERIAL_RX 1
A11: FREE
A12: FREE
A13: FREE
A14: FREE
A15: FREE
B00: FREE
B01: OSD_CS
B02: FREE
B03: LED 1
B04: PPM
B05: USB_DETECT
B06: I2C_SDA 1
B07: I2C_SCL 1
B08: MOTOR 1
B09: MOTOR 2
B10: FREE
B11: FREE
B12: SDCARD_CS
B13: SPI_SCK 2
B14: SPI_MISO 2
B15: SPI_MOSI 2
C13: MPU_EXTI
C14: SDCARD_DETECT
C15: BEEPER
F00: FREE
F01: FREE
F04: FREE
can you type "resource" and post that?
# resource
resource BEEPER C15
resource MOTOR 1 B08
resource MOTOR 2 B09
resource MOTOR 3 A03
resource MOTOR 4 A02
resource MOTOR 5 B07
resource MOTOR 6 B06
resource PPM B04
resource LED_STRIP A08
I have not done anything to this flight controller yet. This will be my first real practice build (X2 ELF).
I did some research. My original idea is likely not going to work. You will probably have to use servo control on a switch. You will have to remap the servo output to the LED pad or beeper pad. Unfortunately, I have never mess with servo control and probably at the end of my knowledge to help you. Here is some reading you can do, and hopefully someone here can help you.
https://github.com/betaflight/betaflight...LT-for-3.1
Thanks for the support. I found some videos on servo tilt and channel forwarding. Will link if useful.
I think I figured it out. Make sure you save a copy of your original resource assignments before making these changes.
In CLI type
resource led_strip none
resource servo 1 A08
save
You need to add a switch to your TX mixer. We will use AUX1(channel 5) as an example.
Go to the servo tab in the configurator (you might have to toggle expert mode). On the servo 0 line, check the A1 box.
Now you can wire your pwm switcher to the LED pad. In theory, this should work.
  • unseen
Nice. I wil gave a go at it when I get back home tomorrow. Smile
Keep us posted
  Betaflight OSD not showing any information, but OSD menu is working gwennoyel 22 9,197 19-Apr-2024, 08:35 PM
Last Post: Maxym666
  Camera Plug Wiring segler999 5 371 30-Dec-2023, 05:17 PM
Last Post: segler999
  Camera and VTX connection best practice? husafreak 9 677 24-Dec-2023, 10:11 PM
Last Post: husafreak
  Betaflight OSD not showing any information in goggles Anton Sky 7 756 22-Oct-2023, 08:57 AM
Last Post: Anton Sky
Question Help Betaflight OSD is not working (F405v3, TX800, Foxeer T-Rex Micro) maggrave 5 1,264 20-Oct-2023, 11:17 PM
