Camera cuts out on Flips and rolls
Hi all Can any one point me out here please
I have my quad start playing on me again
When I do flip or roll cam cuts out for split sec like black screen.
Camera connected from PDB 12v bec and VTX same both connected on MATEC V2.1 PDB
I can do hard punch out without problem but when I do flip roll it cuts cam out
Regards Thinking
I would start with checking all connections are tight/seated including antenna (probably not the problem since it's black screen), connections for power to VTx, power to camera, connection between camera and VTx, if you soldered any wires together to build customized leads check the continuity of them with a multimeter be sure to find a way to keep the leads connected while wiggling the wire.
If everything looks good then next I'd probably take the camera and hook it up to a TV (assuming you have the AV cable that they usually come with) and turn it over to see if it cuts out there... if it doesn't cut out or act funny when turned over, try shaking it while turned over, apply some g-force to it.
Not sure if that'll help, or if any of that is stuff you haven't tried yet, but I figured I'd throw out what came to mind for me.
carl.vegas
  • Darozas
Check connections like Carl sais, but cutting out to a black screen sounds very similar to an OSD reset caused by voltage sag. Do you happpen to have an OSD unit on board?
EDIT: hard punchout is clreating weaker voltage spikes in the system than fast flips and rolls - due to rapid braking and thrusting of motors during stabilisation after flip so this is not a weird behaviour.
  • Darozas
I had this happened to me. Turn out that one of the component desoldered but was still held together by the shrink wrap. Check to see if all the components are still intact.
  • Darozas
(21-Jun-2017, 08:06 PM)KonradS Wrote: Check connections like Carl sais, but cutting out to a black screen sounds very similar to an OSD reset caused by voltage sag. Do you happpen to have an OSD unit on board?
Thanks for reply
But what I notice yesterday that its only cutting out in AIR mode. Its fine in ACRO mode even if I do flip and roll.
In AIR mode it cuts OSD then BLACK screen on flip roll its sounds more to me like Ground issue somewhere.
No I don't have on board OSD got MicroMinimOSD wired up.
But I have received my Omnibus f4 yesterday so gonna install this to see if problem still persist.
Regards
(22-Jun-2017, 08:50 AM)Darozas Wrote: Thanks for reply
Regards
Yes, thats a microminimosd problem (and many others built on the max chip) in my opinion. Try to give it a flight without the osd or put it on a separate power source/give it a filtered one.
Ground loops can be an issue too as suggested above.
Edit: in the past i have noticed that it gets better when the craft is tuned better. That may explain the difference when you enable airmode (you basically had to retune to use it in the past, not sure how it looks like now as i'm not flying without airmode)
I had this problem recently. In my case it was due to voltage spikes and drops from my ESCs caused by the regenerative braking. I installed a voltage step down leading to the vtx to solve the problem.
  Camera Plug Wiring segler999 5 371 30-Dec-2023, 05:17 PM
Last Post: segler999
  Camera and VTX connection best practice? husafreak 9 677 24-Dec-2023, 10:11 PM
Last Post: husafreak
  Best hd camera for 5 inch freestyle drone? PJKMBAKER 3 604 30-Sep-2023, 12:05 PM
  Analog Camera Settings help for night / low light MajorKook 5 1,035 03-May-2023, 04:57 AM
Last Post: cali_quad
  Help analog camera OSD pin nicetomeetyou 10 1,213 15-Apr-2023, 09:22 AM
