Threads: 1
Likes Received: 0 in 0 posts
0 27-May-2016, 07:29 PM (This post was last modified: 28-May-2016, 01:14 AM by BigglesFPV.) I have a Naze32 Rev 5 the the buzzer won't work on. Has anyone had this problem?. If so how did you fix it. It worked for a good while then one day I plugged in and no buzzer.
Threads: 672
Likes Given: 2,027
139 first thing to do would be to confirm your switches are set correctly?
check solder joints of the buzzer pins?
try a different buzzer, or put your current buzzer on a different build/FC see if it works?
if you are desperate to get buzzer working, try to erase the board and flash firmware again, so you can tell if it's hardware or software.
