13-Mar-2019, 11:36 AM
How much do they move? If only a tiny bit, I know that Cleanflight was adding a bit of pitch movement to compensate for raised throttle - is that a possible issue? If that movement is very small, that may be it, otherwise:
Did you set the model to wing in cleanflight/betaflight?
Did you check for correct resource address of motor 3 and 4?
Did you clear the resource address with
before assigning servos?
What do you have set on your radio? Keep in mind that the FC should take care of all mixers etc, so disable those on the TX.
Quote:resource motor 3 none
resource motor 4 none
Find me on Youtube and Instagram. I currently fly: DRC Aura, NOX5R, Minimalist 112 and drive a scrap RC car
