Build Process
Evening Gents......
I have started my first build and I was soldering the leads for the aft port ESC to the pads on the PDB.  I had a brain storm (or maybe a brain fart) and coated the solder joints with liquid tape thinking that it might help prevent a shot circuit in the event of high moisture, or damage from a crash.  Then it dawned on me that perhaps that was not one of my better ideas.....if I have to remove the wires later how difficult will my "brain storm" make it for me?  Photos Attached.  Comments/suggestions?  Thanks guys.
If this is just normal liquid tape it shouldn't be any different from removing a sticker. Just prize one edge up and peel it right off (hopefully)
Hope this helps and makes sense.
lol FPV
Ragg-e WBX 5"
BUILD
MY CHANNEL
Haven't tried to remove it, but I hope you're correct....
Do you use spacer between the PDB and the bolts holding the arms?
My quad:
(10-Mar-2016, 02:48 AM)Luc Wrote: Do you use spacer between the PDB and the bolts holding the arms?
No.  None were provided and I have seen many other builds without spacers.  If everything is properly insulated it shouldn't be a problem...I hope.
It's just a thing to keep in mind, imo i would go for safety. 'Many other' isn't an argument Wink
Have fun building the quad Smile
My quad:
I'm not sure what the safety issue is......
  Build Rekon5 UL 5" build ph2t 51 7,988 12-Apr-2024, 02:26 AM
Last Post: ph2t
  Build Micro Apex 4" Build drumgod 8 390 11-Apr-2024, 12:05 AM
Last Post: BigBeard
  Build Helios - 3.5” Sub-250g (Sub 160g possible) DJI O3 Drone – Frame/Build Thread Recursion 12 1,859 25-Mar-2024, 10:28 PM
Last Post: Recursion
  Build 5in lightweight build hawk01 37 1,360 22-Mar-2024, 10:56 AM
Last Post: Jossey
  Build Whoosh - 3.5" build. PID settings? maxer 23 1,165 30-Dec-2023, 08:29 PM
