16-Dec-2016, 02:53 AM
Flight controller in with ESC's hooked up.....
Build # 3 |
16-Dec-2016, 02:53 AM Flight controller in with ESC's hooked up..... "Damn the torpedoes!!! Full speed ahead!!!" 19-Dec-2016, 12:57 AM Ok....now that Scotty helped me get my head out of my butt (thanks again Scotty), I have rewired the FC and basicly finished the build. Still have some tuning to do, but everything appears to work: ) I did notice that the motors appeared to get quite hot after just a few secinds of running. I used the long screws that came with the motors because the fram is 4mm thick. I suspect they are too long, so that my next task...shorter screws....or washers. Weight without battery is 384g, AUW with 4S 1500mah 60C battery is 552g. Wiring corrected RX and VTX added to stack Antenna tubes added to top plate Tweaker5 "Damn the torpedoes!!! Full speed ahead!!!" 19-Dec-2016, 02:28 AM Nice! Can't wait to see (hear) how it flies. (Sure is a lot of room in that thing...) 19-Dec-2016, 04:16 AM (19-Dec-2016, 02:28 AM)sloscotty Wrote: Nice! Can't wait to see (hear) how it flies. It will probably be next weekend before I get it in the air. Lots going on this week right before Christmas, pluis the weather doesn't look favorable for flying. I'll post some flight video once I get it in the air. I was able to stack everything I needed in the center so it did leave alot of extra room. Thanks for your help Scotty, you da man!! "Damn the torpedoes!!! Full speed ahead!!!" |
Build Rekon5 UL 5" build | ph2t | 51 | 7,925 | 12-Apr-2024, 02:26 AM Last Post: ph2t | |
Build Micro Apex 4" Build | drumgod | 8 | 374 | 11-Apr-2024, 12:05 AM Last Post: BigBeard | |
Build Helios - 3.5” Sub-250g (Sub 160g possible) DJI O3 Drone – Frame/Build Thread | Recursion | 12 | 1,831 | 25-Mar-2024, 10:28 PM Last Post: Recursion | |
Build 5in lightweight build | hawk01 | 37 | 1,336 | 22-Mar-2024, 10:56 AM Last Post: Jossey | |
Build Whoosh - 3.5" build. PID settings? | maxer | 23 | 1,155 | 30-Dec-2023, 08:29 PM Last Post: SnowLeopardFPV |
