Brushless motor maintenance - oil?
I've noticed some vertical play on one of my motor bells (I can pull it up about 1.5mm - DYS BE1806) and decided to rather swop it out with one of my spares.
While I was busy I decided to give them all a proper clean and then this thought occurred...
Can / Should I oil the bearings?
I've got a variety of oils, but the most suited would probably be the Wahl Hair Clipper Blade Oil. It is a very thin oil, and as it can withstand the friction created by clipper blades it should probably be suitable for these bearings.
Thoughts?
If my post helped you...hit the RATE button.
You'll probably get a lot of thoughts about this.  Some will say you shouldn't because the oil will flush out the grease that was put in there when the motor was assembled.  Quite right.  For me, if I have a really old motor that is starting to sound "dry" and the motor bearing is not sealed, I may put a small drop in...no more, otherwise it'll fling it every where and just attract more dirt.  As far as clipper oil, I would not use it.  I don't know if it would withstand the heat and friction of a motor that will spin in excess of 15,000 rpms.  I would use a synthetic oil that is designed for such an application.  I have  some, but dont remember where I got it, or what the brand, or viscosity is.  A google search should turn some up.  All my opinion and I am sure some will disagree.  Good luck!  Smile
Question Help Diatone MXC Taycon Cinewhoop's 4th motor isn't working rr240 2 133 28-Apr-2024, 02:58 PM
Question Help Diatone MXC Taycon Cinewhoop's 4th motor isn't working rr240 0 65 23-Apr-2024, 09:36 PM
Last Post: rr240
  Sometimes a motor surprises you - in a good way mstc 20 851 10-Apr-2024, 09:00 PM
Last Post: mstc
  Help Brother Hobby Motor VY1507 hawk01 3 118 05-Apr-2024, 07:58 AM
  Help Mobula 8 after crash motor ramp up to max with minimum throttle johnny1234 7 1,047 31-Mar-2024, 05:43 AM
Last Post: spiralthomas
