Brushed motor overheating
HI guys need your knowledge, after flash Betaflight 3.1.7 on my QX95 and QX90 the motors start to overheat to much I can't touch it, I'm stock PID and config and also change the PIDs to the normal I use, but the motors get ultra hot
Any help with this issue
Regards
What is your motor pwm rate set at. I had the same problem with a MMW Carbon-H I built and increased the rate to 32,000 and the motors barely got warm. Quieter as well
  • sloscotty
  Build resource remapping on brushed betafpv brushed board Firstcoastfpv 4 157 14-Mar-2024, 03:14 PM
Last Post: iFly4rotors
  Build ACK80 Attack Chicken Walksnail with motor issue Cyberess 11 461 13-Feb-2024, 04:55 PM
  Help Meteor65 pro- motor runs away GhastBoi 7 231 08-Feb-2024, 12:15 AM
  BetaFPV HX115 SE motor replacement? husafreak 22 650 20-Nov-2023, 06:59 AM
Last Post: husafreak
  Build Motor size and kV for lightweight 2.5" toothpick? swequad 18 1,011 01-Oct-2023, 07:27 PM
