Threads: 125
Likes Given: 99
388 I wonder if this is how soft mount came about.
Threads: 30
Likes Received: 1,199 in 755 posts
Likes Given: 714
45 Kinda makes you wonder how important soft mounting really is. I know personally where I've not been able to perceive any difference between soft-mounted and standard nylon standoffs.
Threads: 51
Likes Received: 1,861 in 1,175 posts
Likes Given: 3,315
74 Wow! Gives me new respect for the Martian frame! It held up even when the isolated inner stack didn't!
Threads: 38
Likes Given: 1,881
72 This also says a lot about how it's better to use nylon standoffs than to mount the flight controller with metal screws.
If the stress caused during the crash was enough to shear the nylon screws, imagine what the flight controller would suffer if it was mounted on metal screws!
Threads: 129
Likes Received: 2,740 in 1,644 posts
Likes Given: 2,969
65 (17-Dec-2017, 01:34 PM)unseen Wrote: This also says a lot about how it's better to use nylon standoffs than to mount the flight controller with metal screws.
The "Law of Unintended Consequence" comes in to play. I would rather replace a few 4 cent pieces of nylon than a $100 stack. For that, I have found some standoffs designed to offer vibration dampening. They are brass/aluminum fittings in hard"ish" rubber, allowing some shock absorption and give in a crash event. They seem tough enough to withstand more abuse than the nylon type. I need to crash to test my feelings, so please forgive if I take my time getting the information posted
SoCal Kaity :D
OMG, no one told me it would be this much fun! Addicted :)
Threads: 83
Likes Received: 944 in 654 posts
Likes Given: 2,142
24 (17-Dec-2017, 07:12 PM)kaitylynn Wrote: I need to crash to test my feelings, so please forgive if I take my time getting the information posted
Err, no! Please, at your earliest convenience, go out and smash your beloved Kai-Te into the nearest solid object, I guess tree trunks will suffice, if you can't find any brick walls!?
