16-May-2016, 06:09 PM
If I enable damped light for braking are my self locking prop nuts going to listen and fall off?
Thanks
Thanks
Braking with self locking nuts |
16-May-2016, 06:09 PM If I enable damped light for braking are my self locking prop nuts going to listen and fall off? Thanks 16-May-2016, 11:32 PM No. (The motors will not reverse direction.) 17-May-2016, 12:18 PM Don't worry I never had any sort of proble with prop nuts related to braking either They can I fact go off if you don't tighten them enough. It happened to me while I was flying and quickly let go off the throttle. One of the nuts loosened and the prop fell off. So, make sure to tighten the nuts properly. Or you could get some cw/ccw locknuts from Banggood |
Tip & Trick TPU washer for holding M5 nuts on better. | Suros | 4 | 210 | 18-Apr-2023, 09:45 PM Last Post: Lemonyleprosy | |
Help Mamba 50a 4in1 ESC - Flies fine. One motor has braking? | CarComp | 9 | 381 | 31-Mar-2023, 06:21 AM Last Post: romangpro | |
Is Active braking regenerative? | cche | 1 | 791 | 01-Jun-2017, 11:07 AM Last Post: sushicanfly | |
Help Disable Active Braking in BLHeli_S | sushicanfly | 2 | 3,136 | 08-Oct-2016, 11:32 AM Last Post: sushicanfly | |
braking article | tom12345 | 1 | 848 | 04-May-2016, 02:28 PM Last Post: Oscar |
