Hello all,
I can't believe it, I flew 10 packs and the ESC burned out(i think). Had less than 4 days
Anyway, the current ESC firmware is 0H5, and the target system is 0.19. The drone flew pretty well till i crashed like 2-3 times. It wasn't that hard of crashes tho.
Right after that, my #3 motor cannot spin up. I thought was the bad motor, so I swapped from another motor that didn't spin up. I used the volt meter and tested they all have continuity on all 3 pads. The conclusion has got to be the ESC I think.
So I logged into ESC.Configurator.com and the thing is it sees all 4 ESC as alive and active, I can re-flash the ESC firmware with no problem. I just cannot spin up the motor from BFC or ESC. Conf. I emailed the NBD support too so let's see what they say. Thanks advanced!!!
