Blheli_S firmware
Hello everyone. I have installed the emax bullet 30amp version to a new build.
Out of factory they came flashed with 16.5 version.
When I connected to the blheli suite, I found that there are newer versions available. Has anyone tested them? Are they safe to use?
The newest versions are:
1. 16.67 RC (blheli-mutlishot)
2. 16.63 DSHOT commands (Official)
3. 16.6
4. 16.65
5. 16.5
I can't really comment other than I've been using 16.5 all summer and I just can't imagine my motors running any smoother, so I haven't even bothered upgrading.
Sad
Hi I have Lumenier 30A OPTO 3-6S ESC's which are supposed to have LED lighting. I have downloaded BL_Heli Configurator 16714900 and Also BL_Helisuite 32_32300.  I can connect to these ESC's with both of the above programs.  With the configurator it reads ESC's as J-H-15, 16.43 says running Firmware released Nov 11-2017 00:27:03, I am connecting through my DYSF4 Pro FC, which is flashed to 3.2.2.  When I load either BL_Heli software I do not get the LED Control tabs shown above. Can you tell me what I am doing wrong?
  Can BLHeli_S read PPM Signal srichar3 2 680 06-Dec-2021, 07:52 PM
Last Post: srichar3
  BLHeli_S non-damped mode cjhilder 3 1,454 02-Nov-2021, 07:40 PM
Last Post: cjhilder
  Motors stall with BLHeli_S ESC esantirulo 9 1,733 24-Feb-2021, 02:53 AM
Last Post: voodoo614
  JazzMaverick's BLHeli_S version 16.9 RPM FIlter gabrielaltea 4 10,650 08-Feb-2021, 01:11 AM
Last Post: DIDI
  Need help | BLheli_S Bidirectional Dshot & BF 4.2 Kadirjabbar 11 5,801 05-Feb-2021, 06:18 PM
Last Post: Oscar
