22-Dec-2017, 06:43 PM
whats best reversing motors in BLheli or crossing 2 wires?
BLheli or cross wires? |
22-Dec-2017, 06:43 PM whats best reversing motors in BLheli or crossing 2 wires? 22-Dec-2017, 07:22 PM I used to take great pains to test each motor before soldering, then crossing wires on appropriate motors. Now I prefer the "flat wires" look and don't bother anymore. I recommend reverse in BLHeli and go fly. thanks for that i DL both chrome version and official BLheli chrome looks the simple , lots of pdf's came with the official version and chrome is very small. no brainer its chrome version . yikes ,i had a rapid heart beat for a moment . thought i would connect up my current flyer for giggles to just see what the eachine250 simonk 12A esc's had to say . opened BHC asked kindly for the setup and caressed the mouse . get the esc's to sing , but nothing comes up . should be the 2 panels with the choices,,,ok so i back out disconnect configurator ,next the usb and battery, reconnect the the battery and the esc's didn't give the normal song. just started beeping and did not stop!!!!!!!!!!!!!!!!!!! wash, rinse, repeat , still with the insensate beeping .. ok now what? found that if you open CF ,connect battery and low and behold everything cleared up got the regular song .. disconnect everything and reconnect battery and everything is normal. wonder if the crossed motor wires had anything to do with the weird reaction? 22-Dec-2017, 10:58 PM The clue is in the name: "simonk" The ESCs are not running BLHeli! 22-Dec-2017, 11:46 PM 23-Dec-2017, 12:01 AM Most of the designs that run SimonK firmware will also run BLHeli, but there wouldn't be much point in calling it a SimonK ESC if it wasn't running SimonK firmware! |
Trying to fix GHF411 - motor barely moves. No BLHeli chime | romangpro | 0 | 185 | 22-Aug-2022, 07:21 AM Last Post: romangpro | |
HSKRC ESC 45A 2-4S BLHeli-S DSHOT600 | fra_gra | 2 | 587 | 04-Jul-2022, 01:18 PM Last Post: fra_gra | |
Solved T-Motor F55A 4in1 --> 2 esc's not showing in BF and BLHeli | RobinS | 7 | 1,962 | 23-May-2021, 06:49 AM Last Post: Kevin2112 | |
What's the best BLheli FW/Setting for fixed wing? | GlidLov | 3 | 3,789 | 20-Apr-2020, 10:50 PM Last Post: voodoo614 | |
Problem Holybro Esc 4in1 in BLHeli | SBLAUS | 13 | 1,968 | 26-Jul-2019, 02:12 PM Last Post: SBLAUS |
