BLHeli error writing to the flash
Hello,
I have written this exact post on the cleanflight flashing tutorial on Oscars blog but I thought posting it here might be easier.
I have been expericencing some troubles trying to flash my DYS SN20A ESC's with the latest firmware. From factory they come shipped with BLHeli 14.0 so naturally i wanted to update them to 14.4. I am using cleanflight to do so and i have gotten the ESC's to connect. I could read the settings and see that they were all on 14.0 and i could also see that one ESC was out of sync. As soon as i try to use the flash firmware feature I am met with an error. "Error writing to the flash", when clicking OK you get "Failed to write to Flash! ("Write failed" error)" and then finally "ESC#3: Flash FAILED. DYS_SN20A (Multi) BLHeli Rev: 14.4.
And now when you check the ESC status it says **FLASH*FAILED** instead of the version as if the current firmware now has been corrupted. To me it seems like quite an odd problem in that i can read the chip but not write to it. I was hoping that you or someone else could maybe help me out.
Im looking forward to reading the answers.
Thanks in advance.
- Oliver
I remember one of my friends had this problem after a hard crash, the ESC works, but no longer able to be flashed...
sorry it's just one of those weird problems I don't have an answer myself...
Yeah I thought so too... Thanks for the response though =D
damn happend to me today ... so no solution Sad
o and i didnot even crash hard i was flying and suddenly drop out the sky...
I was trying to flash 14.4 again after i tried 14.5 also no luch and same error flash failed but after selecting firmwas 14.3 it was flashing succesfully.
and now its flashing the latest 14.5
Dont be Stupid , Fly safe. / BornforFPV.eu - Youtube
(08-May-2016, 08:26 AM)Sven Wrote: damn happend to me today ... so no solution Sad
hi sven did you figure out your problem ? i had same issue with non used little bee 20a escs. i can get in to blheli ( cc3d with fdti pass through ) but i can't flash little bees
Did you try using an arduino board instead of the passthrough? I had a flashing error before and in order for me to flash it properly, I had to use arduino. Once it was flashed then I was able to freely use passthrough.
(29-Jun-2016, 07:57 PM)trojanGoat Wrote: Did you try using an arduino board instead of the passthrough?  I had a flashing error before and in order for me to flash it properly, I had to use arduino.  Once it was flashed then I was able to freely use passthrough.
I figured out with naze32 rev5 pass through. Thank you Smile
Little bee 20a esc not flashable with arduino nano v3
  DJI FPV Drone Combo / Dji Flash LaserBrain 1 445 22-Feb-2021, 01:45 PM
Last Post: Ljholland
  SQL error? Krohsis 10 582 23-Jan-2021, 12:49 PM
  Solved Need help writing a logical switch. roger74 12 1,004 24-Aug-2019, 12:24 PM
Last Post: Krohsis
  SD CARD ERROR expected version 2.2v0016 taranis x9d IrishFlight 2 5,080 29-Mar-2019, 02:00 PM
Last Post: IrishFlight
  Chromebooks for BF and BLheli Chris_76227 11 4,812 20-Sep-2017, 05:49 AM
Last Post: unseen
